Internet issues.
- Re: Internet issues.
- « Previous
- 1
- 2
- Next »
28-10-2014 2:18 PM
Just looked at my router admin page to see if anything happened while I was sleeping, turns out I've had YET ANOTHER disconnect with at least 15 minutes of PPP Server No Response, probably longer than that but my router doesn't scroll that far.
Anyone care to look into this further?
EDIT; Time of disconnects were prior to 11:10am (this is when it the connection came back up) according to my router.
Router log in case it helps any;
Oct 28 10:54:58 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:54:58 daemon pppd[11373]: Doing disconnect
Oct 28 10:55:01 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:55:04 syslog -- MARK --
Oct 28 10:55:08 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 10:55:08 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 10:55:18 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 10:55:18 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 10:55:21 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 10:55:21 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 10:55:24 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:55:24 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:55:24 daemon pppd[11373]: Doing disconnect
Oct 28 10:55:27 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:55:50 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:55:50 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:55:50 daemon pppd[11373]: Doing disconnect
Oct 28 10:55:53 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:56:16 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:56:16 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:56:16 daemon pppd[11373]: Doing disconnect
Oct 28 10:56:19 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:56:42 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:56:42 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:56:42 daemon pppd[11373]: Doing disconnect
Oct 28 10:56:45 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:57:08 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:57:08 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:57:08 daemon pppd[11373]: Doing disconnect
Oct 28 10:57:11 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:57:29 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 10:57:29 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 10:57:34 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:57:34 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:57:34 daemon pppd[11373]: Doing disconnect
Oct 28 10:57:37 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:58:00 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:58:00 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:58:00 daemon pppd[11373]: Doing disconnect
Oct 28 10:58:03 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:58:26 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:58:26 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:58:26 daemon pppd[11373]: Doing disconnect
Oct 28 10:58:29 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:58:52 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:58:52 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:58:52 daemon pppd[11373]: Doing disconnect
Oct 28 10:58:55 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:59:18 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:59:18 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:59:18 daemon pppd[11373]: Doing disconnect
Oct 28 10:59:21 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 10:59:40 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 10:59:40 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 10:59:44 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 10:59:44 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 10:59:44 daemon pppd[11373]: Doing disconnect
Oct 28 10:59:47 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:00:10 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:00:10 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:00:10 daemon pppd[11373]: Doing disconnect
Oct 28 11:00:13 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:00:36 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:00:36 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:00:36 daemon pppd[11373]: Doing disconnect
Oct 28 11:00:39 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:01:02 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:01:02 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:01:02 daemon pppd[11373]: Doing disconnect
Oct 28 11:01:05 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:01:28 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:01:28 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:01:28 daemon pppd[11373]: Doing disconnect
Oct 28 11:01:31 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:01:54 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:01:54 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:01:54 daemon pppd[11373]: Doing disconnect
Oct 28 11:01:57 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:02:20 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:02:20 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:02:20 daemon pppd[11373]: Doing disconnect
Oct 28 11:02:23 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:02:25 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 11:02:25 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 11:02:46 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:02:46 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:02:46 daemon pppd[11373]: Doing disconnect
Oct 28 11:02:49 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:03:12 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:03:12 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:03:12 daemon pppd[11373]: Doing disconnect
Oct 28 11:03:15 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:03:38 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:03:38 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:03:38 daemon pppd[11373]: Doing disconnect
Oct 28 11:03:41 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:04:04 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:04:04 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:04:04 daemon pppd[11373]: Doing disconnect
Oct 28 11:04:07 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:04:30 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:04:30 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:04:30 daemon pppd[11373]: Doing disconnect
Oct 28 11:04:33 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:04:56 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:04:56 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:04:56 daemon pppd[11373]: Doing disconnect
Oct 28 11:04:59 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:05:19 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 11:05:19 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 11:05:22 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:05:22 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:05:22 daemon pppd[11373]: Doing disconnect
Oct 28 11:05:25 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:05:48 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:05:48 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:05:48 daemon pppd[11373]: Doing disconnect
Oct 28 11:05:51 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:06:14 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:06:14 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:06:14 daemon pppd[11373]: Doing disconnect
Oct 28 11:06:17 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:06:40 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:06:40 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:06:40 daemon pppd[11373]: Doing disconnect
Oct 28 11:06:43 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:07:07 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:07:07 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:07:07 daemon pppd[11373]: Doing disconnect
Oct 28 11:07:10 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:07:33 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:07:33 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:07:33 daemon pppd[11373]: Doing disconnect
Oct 28 11:07:36 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:07:59 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:07:59 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:07:59 daemon pppd[11373]: Doing disconnect
Oct 28 11:08:02 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:08:25 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:08:25 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:08:25 daemon pppd[11373]: Doing disconnect
Oct 28 11:08:28 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:08:28 daemon UPNPD[11089]: ioctl(s, SIOCGIFADDR, ...): No such device
Oct 28 11:08:28 daemon UPNPD[11089]: Failed to get ip address for interface ppp_ewan_1
Oct 28 11:08:51 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:08:51 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:08:51 daemon pppd[11373]: Doing disconnect
Oct 28 11:08:54 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:09:17 daemon pppd[11373]: Couldn't get channel number: Transport endpoint is not connected
Oct 28 11:09:17 daemon pppd[11373]: PPP: PPP Server No Response !!!
Oct 28 11:09:17 daemon pppd[11373]: Doing disconnect
Oct 28 11:09:20 daemon pppd[11373]: PPP: Start to connect ...
Oct 28 11:09:40 daemon pppd[11373]: PPP server detected.
Oct 28 11:09:40 daemon pppd[11373]: PPP session established.
Oct 28 11:09:40 daemon pppd[11373]: Using interface pppewan_1
Oct 28 11:09:40 daemon pppd[11373]: Connect: ppp_ewan_1 <--> eth0
Oct 28 11:09:40 daemon pppd[11373]: Couldn't increase MTU to 1500.
Oct 28 11:09:40 daemon pppd[11373]: Couldn't increase MRU to 1500
Oct 28 11:09:40 daemon pppd[11373]: PPP LCP UP.
Oct 28 11:09:41 daemon pppd[11373]: Couldn't increase MRU to 1500
Oct 28 11:09:41 daemon pppd[11373]: PPP LCP UP.
Oct 28 11:09:41 daemon pppd[11373]: local IP address x.x.x.x
Oct 28 11:09:41 daemon pppd[11373]: remote IP address x.x.x.x
Oct 28 11:09:41 daemon pppd[11373]: primary DNS address 212.159.6.9
Oct 28 11:09:41 daemon pppd[11373]: secondary DNS address 212.159.6.10
Oct 28 11:09:41 daemon dnsmasq[91]: using nameserver 212.159.6.10#53
Oct 28 11:09:41 daemon dnsmasq[91]: using nameserver 212.159.6.9#53
Oct 28 11:09:41 daemon pppd[11373]: Received valid IP address from server. Connection UP.
Oct 28 11:09:42 user syslog: begin: interface: ppp_ewan_1 go to up
Oct 28 11:09:43 daemon UPNPD[11089]: received signal 15, good-bye
Oct 28 11:09:45 daemon UPNPD[15525]: HTTP listening on port 2800
Oct 28 11:09:47 user syslog: end: interface: ppp_ewan_1 go to up
Message 16 of 23
(588 Views)
28-10-2014 5:42 PM
This warrants a reply.
Spoken with my father, who informed me that the connection went down sometime in the early morning, according to him around 1-2am was when his ps3 notified of a connection error, he couldn't get connected at all this morning either before he left the house, he's only recently returned so this is fresh news to me.
If the connection was down for that entire period, estimated 9hrs, then you guys really need to take a serious look at this one.
Message 17 of 23
(588 Views)
29-10-2014 4:31 PM
Hi Method0ne,
As per our discussion on Twitter, you can see a graph of your connection logs below. Stability seems to be good aside from the odd drop every few days. It certainly doesn't fit the profile of what we would normally class as an intermittent connection fault which can contain hundreds of drops and reconnections over the course of a day or even a few hours however this doesn't detract from the fact that there are still drop occurring.
<img src="http://community.plus.net/visualradius/generated/image14146002779485.png"/>
Message 18 of 23
(588 Views)
29-10-2014 4:44 PM
Firstly thanks for the responses.
While I agree it may not seem so bad, up until the 13th of this month I'd never to the best of my knowledge had any drops at all, and when coupled with the fact that it can take minutes for the connection to return to stable (nearly 45 minutes the first time it happened, 2-15 minutes every other time I've noticed it) it makes me wonder whether this is something that's going to increase in frequency and severity.
There has to be something causing this, and from the errors my router log produces, notably the PPP Server No Response, I can only surmise this is something outside of my control.
Hopefully someone can nail this down and fix whatever the issue is, and if there's anything I can do to help I will, I just have nothing to go on.
Message 19 of 23
(588 Views)
30-10-2014 10:48 AM
At the request of support staff I've just swapped out to the PN supplied Technicolor TG582n, got my network set up, connected to the internet using it, and within 2 minutes of doing so the router rebooted of it's own accord with no intervention.
That's not a good start.
Also doesn't help that the control interface is slower than your average turtle.
Message 20 of 23
(588 Views)
30-10-2014 3:33 PM
Just had YET ANOTHER random disconnection, this time with the plusnet supplied router, proving that it's not my hardware or anything at my end that is at fault.
Message 21 of 23
(588 Views)
30-10-2014 4:40 PM
Just to confirm, the latest drop (1531) was our side dropping you (Admin reset) usually done if the profile speed changes.
The 1040 drop is unexplained, but it's worth keeping an eye on the situation a little bit longer so we can see the drops over the course of the night/weekend/week.
Tony
Tony
Message 22 of 23
(588 Views)
02-11-2014 8:47 AM
Here's an interesting flaw in trying to monitor my connection status with the TG582n, after a couple of days having it connected I could no longer get access, either wired or wifi, to the web interface. Internet access wasn't affected, but as I was unable to monitor for any drops this was not an ideal situation.
I've had to do a reset of the router to get monitoring back, but since this wasn't a clean disconnect if I get another random drop or if the web interface fails again I'm going to be looking at DLM intervention where it isn't needed. Swapping back to the PN supplied hardware was supposed to help diagnose this problem but frankly if I can't monitor my connection then what good does it do.
Message 23 of 23
(588 Views)
- « Previous
- 1
- 2
- Next »
