Internet frequently disconnects at random times
- Internet frequently disconnects at random times
16-12-2018 10:42 AM
Hello Community,
I took up a new Plusnet broadband service in November and so far I'm really enjoying the service.
However, over the last week I've run into a few issues with internet stability. Whenever I jump on my PC to use the service, the connection itself drops out. This could be at any time and doesn't seem to have any form of pattern, although seems to occur more often when I try to use the internet.
I have tried removing the face plate from the master socket and plugging the microfilter directly into the socket, although there is not change to the degradation overall.
If there are any more home tests I can do please let me know. Otherwise hoping there may be a fault that is disrupting the service.
Thanks.
Re: Internet frequently disconnects at random times
17-12-2018 9:17 AM
Hi @lakortha, thanks for your post and welcome to our Community Forum!
We're sincerely sorry to hear of the issues you're experiencing with your connection.
We've had a check of the connection and there definitely seems to be something out of place somewhere as we can see quite a few dropouts, although our tests aren't picking up exactly what's causing the issue so we will have to do some troubleshooting to start ruling things out.
We'd recommend starting with basic checks here.
If the problem still persists from here please let us know and we'll then go down the route of raising an issue with Openreach for further investigation.
17-12-2018 12:30 PM
Hi @OskarPapa, thank you for your response.
I have gone through the troubleshooting guide recommended and I can confirm the following:
- The phone line in does not have any crackle at present.
- I have reconnected all my cables. This includes re-seating the microfilter, rebooting the hub one router and re-seating the DSL connection from the microfilter, as well as re-seating the ethernet cable between the router and my PC.
- I am using the master socket which the original hardware technician set up for me from the original install and setup.
Hope this helps provide some more clarity.
Thanks again.
17-12-2018 2:50 PM
Hi @lakortha, could you report the issue on the account over at https://faults.plus.net and let us know once you've done this please.
We'll then be able to get that picked up and raised with our suppliers for further investigation.
Thanks.
17-12-2018 3:11 PM
17-12-2018 3:30 PM
Hi there.
Thanks for raising the fault.
I've updated your ticket for you now which you can view and reply to from here: https://www.plus.net/wizard/?p=view_question&id=185638588 if you can drop us a reply over here when you've replied with your availability for an engineer to visit we'll be happy to book the appointment in as soon as we can.
17-12-2018 4:18 PM
Hi @Gandalf,
Thank you very much. I have responded to the ticket with my availability.
Thank you once again.
17-12-2018 4:27 PM - edited 17-12-2018 4:28 PM
17-12-2018 4:54 PM
Will do, thank you once again for the excellent service.
17-12-2018 4:58 PM
23-12-2018 9:26 PM
Thanks again,
So a technician came round on Thursday as planned, and identified that the home I live in was still using some old cabling to the cab, so he replaced the cabling with new copper cabling and installed a new 5C master socket.
Whilst the disconnects have certainly improved, I am still experiencing them but on a much smaller scale, just experienced the same disconnect at about 9:15pm on the 23rd. Any other suggestions?
24-12-2018 11:03 AM - edited 24-12-2018 11:04 AM
Hi @Iakortha,
I'm sorry to hear that you're still experiencing disconnections following the engineer visit.
I can see from your connection log that you have experienced multiple drops since yesterday evening:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 79.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 148.0 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-12-20T13:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 719.0 Sec | 900.0 Sec | 896.7 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-12-24T10:27:24Z | 2018-12-24T10:42:24Z |
Ingress Code Violation | 4 | 2 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Unfortunately, testing your line from here isn't picking up the cause of this so we'll need to arrange another engineer visit so that this can be investigated further. Please can you reply to the ticket here with your availability? If you drop us another message on here once you've done this, we'll pick this back up and get your appointment booked in for the earliest available suitable slot.
24-12-2018 1:25 PM
Thanks very much, I have responded on the fault ticket and will continue to do so from there.
Once again, thank you to the Plusnet team for the ongoing support with this problem - it is greatly appreciated.
24-12-2018 2:17 PM
Hi @lakortha, thanks for your post.
We're always more than happy to help but we do really appreciate your kind words.
We've updated the ticket with the news that we've booked in an engineer visit between 08:00 and 13:00 on 27/12/2018.
Please let us know how the engineer visit goes, or if you need any further help in the meantime.
28-12-2018 10:43 AM
Hi @OskarPapa,
So I had an openreach technician attend yesterday, again lovely person, very courteous etc etc.
He inspected the new copper cable to the cab which was fine, and then moved my line onto a new switch / board within the cab itself and made some calls back to someone who controls the connections from the cab. We even tried plugging my router directly into a mains socket as opposed to an extension socket.
All was fine until the evening. I had a pair of DC's and as of 11:30pm last night my internet connection will not restore itself, the Hub Plus One is displaying an orange solid light. I have tried re-connecting the DSL cable to the 5C master socket, rebooting the router, restoring factory settings from the web page and hard resetting from the router itself, no joys what so ever. Looks like there is still a problem somewhere. I have not seen anything about an outage so guessing this is just my line.
Thanks again.
