Internet drops when Answer machine picks up
Dhaos
As the title says the internet drops out/Hangs when the answer machine picks up, it is otherwise fine when answering the phone normaly, anyone any idea what is causing this?
12 REPLIES 12
Chris
Legend
Fixes: 169
Re: Internet drops when Answer machine picks up
Is the answer machine connected to the phone socket via a filter?
Dhaos
No, im on fibre so i have one of the new faceplates.
Chris
Legend
Fixes: 169
The answerphone is plugged in to that socket though?
Can you plug a single phone into the socket and dial 17070, listen for any noises at all on the line.
Dhaos
Haven't got a corded phone on hand so i cannot do a test at the moment.
Chris
Legend
Fixes: 169
Do you have any phone handset available? I'm wondering if the broadband disconnects if you answer the phone too (as really that's all the answerphone is doing).
Dhaos
Yes i have tried that chris, i rang the homephone from my mobile answered it and its fine, its only if the answer machine picks up.
Chris
Legend
Fixes: 169
I'm just running a couple of line tests, but it might be the answerphone that's the culprit!
Chris
Legend
Fixes: 169
We're not actually seeing these drops either.
The line tests haven't shown any problems at all.
Are you using the openreach modem with our router, or have you replaced them with a different piece of kit?
Dhaos
using the asus n56, maybe its the router thats actually locking/hanging, i have a similar problem with the youtube app on 1 of my 3 devices, it locks the router up.
MatthewWheeler
Fixes: 479
It might be worth trying the Openreach modem and our router if you can.
That should point out if its the ASUS that's causing the issues.
 Matthew Wheeler
jelv
Fixes: 10
Quote from: Chris
So having looked at the radius graph to see if there were any PPP drops did you then check the ADSL log to see if he was having loss of sync that resynced quickly enough for the PPP session not to drop?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MatthewWheeler
Fixes: 479
From testing the customers line there's only been one loss of sync within the past 14 days so the modem does appear to be keeping sync.
 Matthew Wheeler
