Internet drops out when phone rings
mlc100
I'm a bit slow on the uptake but realised this only started happening when plusnet/bt moved my socket. It's now a real problem with three of us working at home. Help!
2 REPLIES 2
Fixes: 418
Re: Internet drops out when phone rings
Is your master socket one of the latest types.with a clip on front? If so some are unreliable.
Either way try removing the front section of the master socket, if it’s the old type you may need to remove two screws. Then plug a filter in the test socket, which you will find in the fixed part of the master socket and see if using that fixes your problem.
KatieC
Fixes: 11
Hi @mlc100
Sorry to hear of the problems with your broadband, and for the delay in responding.
I have addressed the issue via a ticket on your account, which you can view online here.
Please do let us know if you have any further questions!
 Katie C
