Internet dropping out every 5 minutes!
thurrafork
Hello folks
So I've had problems with dropping connections over the last few months but this evening it seems to have gone crazy.
It'd dropping out every 5 minutes!
This is a wired connection. I have a Hub One. And I can very clearly see the reassuring blue light replaced by the flashing orange 'B' every few minutes. It then goes through it's process of reconnecting, but then disconnects again a few minutes later.
What could be going on?Huh
Please help!
Here's a bit of the Event Log...
22:30:08, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1408-​>[52.17.7.239]:443 on ppp3)
22:30:07, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1396-​>[35.241.45.82]:443 on ppp3)
22:30:04, 05 Feb. ( 1918.740000) CWMP: session closed due to error: Timeout
22:30:03, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1408-​>[52.17.7.239]:443 on ppp3)
22:29:59, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1410-​>[37.157.6.246]:443 on ppp3)
22:29:58, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1408-​>[52.17.7.239]:443 on ppp3)
22:29:58, 05 Feb. BLOCKED 1 more packets (because of Packet invalid in connection)
22:29:57, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1396-​>[35.241.45.82]:443 on ppp3)
22:29:55, 05 Feb. BLOCKED 1 more packets (because of Packet invalid in connection)
22:29:54, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1408-​>[52.17.7.239]:443 on ppp3)
22:29:54, 05 Feb. BLOCKED 1 more packets (because of Packet invalid in connection)
22:29:53, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:1408-​>[52.17.7.239]:443 on ppp3)
22:29:53, 05 Feb. BLOCKED 3 more packets (because of Packet invalid in connection)
22:29:52, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1402-​>[18.192.234.191]:443 on ppp3)
22:29:52, 05 Feb. BLOCKED 1 more packets (because of Packet invalid in connection)
22:29:51, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1417-​>[52.17.7.239]:443 on ppp3)
22:29:51, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1388-​>[212.159.8.2]:443 on ppp3)
22:29:50, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1402-​>[18.192.234.191]:443 on ppp3)
22:29:50, 05 Feb. BLOCKED 2 more packets (because of Packet invalid in connection)
22:29:49, 05 Feb. BLOCKED 5 more packets (because of Packet invalid in connection)
22:29:48, 05 Feb. BLOCKED 1 more packets (because of First packet is Invalid)
22:29:48, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1394-​>[178.249.97.99]:443 on ppp3)
22:29:48, 05 Feb. BLOCKED 10 more packets (because of Packet invalid in connection)
22:29:48, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:1402-​>[18.192.234.191]:443 on ppp3)
22:29:47, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1394-​>[178.249.97.99]:443 on ppp3)
22:29:47, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1388-​>[212.159.8.2]:443 on ppp3)
22:29:45, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1382-​>[216.58.206.130]:443 on ppp3)
22:29:45, 05 Feb. BLOCKED 12 more packets (because of Packet invalid in connection)
22:29:44, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1388-​>[212.159.8.2]:443 on ppp3)
22:29:44, 05 Feb. BLOCKED 9 more packets (because of Packet invalid in connection)
22:29:43, 05 Feb. BLOCKED 7 more packets (because of Packet invalid in connection)
22:29:42, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1388-​>[212.159.8.2]:443 on ppp3)
22:29:42, 05 Feb. BLOCKED 2 more packets (because of Packet invalid in connection)
22:29:41, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1382-​>[216.58.206.130]:443 on ppp3)
22:29:41, 05 Feb. BLOCKED 6 more packets (because of Packet invalid in connection)
22:29:40, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1382-​>[216.58.206.130]:443 on ppp3)
22:29:40, 05 Feb. BLOCKED 3 more packets (because of Packet invalid in connection)
22:29:39, 05 Feb. BLOCKED 17 more packets (because of Packet invalid in connection)
22:29:38, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:1394-​>[178.249.97.99]:443 on ppp3)
22:29:38, 05 Feb. BLOCKED 6 more packets (because of First packet is Invalid)
22:29:38, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1410-​>[37.157.6.246]:443 on ppp3)
22:29:38, 05 Feb. BLOCKED 10 more packets (because of Packet invalid in connection)
22:29:37, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1388-​>[212.159.8.2]:443 on ppp3)
22:29:37, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:1388-​>[212.159.8.2]:443 on ppp3)
22:29:36, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1389-​>[204.79.197.219]:443 on ppp3)
22:29:34, 05 Feb. ( 1888.710000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:29:29, 05 Feb. ( 1883.770000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:29:29, 05 Feb. ( 1883.760000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:29:27, 05 Feb. ( 1882.210000) WAN operating mode is VDSL
22:29:27, 05 Feb. ( 1882.200000) Last WAN operating mode was VDSL
22:29:26, 05 Feb. ( 1881.020000) PPP IPCP Receive Configuration ACK
22:29:26, 05 Feb. ( 1881.020000) PPP IPCP Send Configuration Request
22:29:26, 05 Feb. ( 1881.010000) PPP IPCP Receive Configuration NAK
22:29:26, 05 Feb. ( 1881.000000) PPP IPCP Send Configuration ACK
22:29:26, 05 Feb. ( 1881.000000) PPP IPCP Receive Configuration Request
22:29:26, 05 Feb. ( 1881.000000) PPP IPCP Send Configuration Request
22:29:25, 05 Feb. ( 1880.020000) PPPoE is up -​ Down Rate=76344Kbps, Up Rate=19139Kbps; SNR Margin Down=6.0dB, Up=12.7dB
22:29:25, 05 Feb. ( 1880.000000) CHAP authentication successful
22:29:25, 05 Feb. ( 1879.960000) CHAP Receive Challenge
22:29:25, 05 Feb. ( 1879.960000) Starting CHAP authentication with peer
22:29:25, 05 Feb. ( 1879.960000) PPP LCP Receive Configuration ACK
22:29:25, 05 Feb. ( 1879.950000) PPP LCP Send Configuration Request
22:29:25, 05 Feb. ( 1879.950000) PPP LCP Receive Configuration Reject
22:29:25, 05 Feb. ( 1879.950000) PPP LCP Send Configuration ACK
22:29:25, 05 Feb. ( 1879.940000) PPP LCP Receive Configuration Request
22:29:25, 05 Feb. ( 1879.940000) PPP LCP Send Configuration Request
22:28:37, 05 Feb. ( 1831.360000) PTM over DSL is up
22:26:11, 05 Feb. ( 1685.390000) CWMP: session closed due to error: Could not resolve host
22:26:11, 05 Feb. ( 1685.380000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:26:11, 05 Feb. ( 1685.370000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:25:40, 05 Feb. ( 1655.090000) CWMP: session closed due to error: Could not resolve host
22:25:40, 05 Feb. ( 1655.070000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:25:40, 05 Feb. ( 1655.070000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:25:40, 05 Feb. ( 1654.780000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
22:25:38, 05 Feb. ( 1653.260000) PTM over DSL is down after 4 minutes uptime
22:25:38, 05 Feb. ( 1653.260000) PPPoE is down after 3 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
22:25:36, 05 Feb. ( 1650.750000) PPP LCP Send Termination Request [User request]
22:25:24, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1247-​>[52.142.114.2]:443 on ppp3)
22:25:03, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1296-​>[151.101.18.133]:443 on ppp3)
22:24:51, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1288-​>[178.249.101.98]:443 on ppp3)
22:24:51, 05 Feb. BLOCKED 3 more packets (because of Packet invalid in connection)
22:24:50, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1283-​>[13.224.226.104]:443 on ppp3)
22:24:49, 05 Feb. BLOCKED 1 more packets (because of First packet is Invalid)
22:24:48, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1272-​>[13.224.132.36]:443 on ppp3)
22:24:47, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1258-​>[143.204.189.37]:443 on ppp3)
22:24:39, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1247-​>[52.142.114.2]:443 on ppp3)
22:24:18, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1296-​>[151.101.18.133]:443 on ppp3)
22:24:06, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1288-​>[178.249.101.98]:443 on ppp3)
22:24:06, 05 Feb. BLOCKED 3 more packets (because of First packet is Invalid)
22:24:05, 05 Feb. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1283-​>[13.224.226.104]:443 on ppp3)
22:24:04, 05 Feb. BLOCKED 1 more packets (because of Packet invalid in connection)
22:24:03, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1272-​>[13.224.132.36]:443 on ppp3)
22:24:02, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1258-​>[143.204.189.37]:443 on ppp3)
22:23:54, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1247-​>[52.142.114.2]:443 on ppp3)
22:23:38, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1287-​>[35.241.45.82]:443 on ppp3)
22:23:33, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1296-​>[151.101.18.133]:443 on ppp3)
22:23:29, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:1279-​>[34.240.2.137]:443 on ppp3)
22:23:29, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1287-​>[35.241.45.82]:443 on ppp3)
22:23:24, 05 Feb. OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.64]:1279-​>[34.240.2.137]:443 on ppp3)
22:23:24, 05 Feb. BLOCKED 1 more packets (because of Packet invalid in connection)
2 REPLIES 2
Aspiring Legend
Fixes: 120
Re: Internet dropping out every 5 minutes!
@thurrafork This looks like a continuation of the previous problem - as you were advised at the time, it now looks as though you need to raise this via faults.plus.net.
thurrafork
Hello again
And now everything is fine again!
It was disconnecting like clockwork every 4 minutes for about 16 hours, and then last night it reconnected and stayed connected!
Nothing changed. I had attempted no fix. I had not wiggled the wiring.
Yes, this is very possibly associated with some ongoing underlying problem that may well rear it's head again, but it's so odd.
Previously it would be dropouts. Random. At it's worst a few times a day.
But this recent episode was unlike anything previous. It was so regular. It was so cyclical I was starting to think it might be some kind of overheat>shutdown>cooldown>restart>overheat pattern, but I just don't know.
Then I thought it might be something to do with the "PPP LCP Send Termination Request [User request]" log event, which always preceded each disconnect. This seems to have appeared quite often with Plusnet/BT connection issues, and was often found to be down to a faulty router.
I just don't know.
I have a boxed BT Smart Hub rattling around somewhere, so if problems reappear I might try swapping in that.
We'll see.
In the meantime, my unskilled speculation aside, does anyone have any notion as to what could cause this kind of 4 minute cycling disconnect pattern?
Thanks.
