Internet dropping at same point every day
- Internet dropping at same point every day
20-06-2017 8:16 PM
Hi guys,
I've been having a problem the last few days where my internet has been dropping pretty much at 8pm on the dot. My router (the standard plusnet hub) goes orange, and my internet dies for about 2/3 minutes. My dad has also experienced this at 11am-ish but I'm at work in the day so can't test this.
Apart from these drops I'm getting very good constant speeds.
Is anyone able to check my line, or have any idea what might be causing this? In the grand scheme of things, it's not a huge problem but does interfere with the small window of internet time I get in a day.
Thanks in advance,
Dan.
Re: Internet dropping at same point every day
21-06-2017 9:56 AM
Hi Dan,
The drops look quite random and are happening throughout the day too:
Is there any noise on the phone line when you dial 17070 and run the quiet line test?
21-06-2017 6:50 PM
Hi Chris,
I ran the quiet line test and it was indeed quiet. There was no noise whatsoever.
As far as I know, there shouldn't really be anything in my house causing these drops. Would something like a sky box connected to the internet cause it to drop?
22-06-2017 9:39 AM
It shouldn't do, however it's not the most unlikely thing I'd have heard affecting a connection (1 specific train that went near someone's house every 2 days was a fun one to track).
Anything that can cause an electrical signal can impact the connection, however unless the power unit is very close to the router then it's quite unlikely.
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 68.8 Mbps | ||||
Upstream Speed | 11.4 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 577.8 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed on Week Days | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 12:45 to 13:00 | ||||
Interference Location | Other | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-06-09T09:45:00 |
If the drops become too frequent I'd advise getting this reported to us as a fault at https://faults.plus.net
09-07-2017 10:01 AM
Just updating to say that the problem is still happening but alot more often. I've only just got back from holiday, but my dad has commented on the internet dropping when he's been using his computer (he uses a com maybe 20 mins a day), and since I've been using it this morning it's dropped 4/5 times between 6.30am and now (10am).
I have raised a ticket because it's getting a bit silly now. If there are any tests that I can do to help figure out the problem then let me know.
Also is there a way for me to view the drop outs like the picture in your post shows? Would be interesting to see exactly when the router is disconnecting, and maybe figuring out why it's happening.
Thanks again.
09-07-2017 1:42 PM
Looking at the connection logs, they seem very consistent with disconnection often at exactly the same points of the day.
This suggests something is causing interference at those times, does anything happen either in the house or the local area you can think of at 1am, 8am, Midday and 7-8pm?
02-08-2017 8:10 PM
Hi. I haven't replied in a while as we had an engineer come and check our connection. He used his laptop to find a faulty connection on a telephone pole about 100 metres away, and did his best to fix it. It didn't completely fix our problem but did make it less common throughout the day.
Unfortunately, over the last week or two, our internet has been dropping out more and more. A couple of times it has dropped out over night and not being able to reboot itself, so we would have to restart the router in the morning.
I've counted 3 drops today since I've been home, approximately 1 at 6.30am, 1 at 6.30pm and one at 7.30pm.
Can you please check our connection to see exactly how often we are getting disconnected?
Also, the only thing that may interfere is a wireless gadget we have for our water boiler, but we have turned that off in an attempt to rule it out.
04-08-2017 1:37 PM
It doesn't look good:
I'd certainly get this reported to us over at http://faults.plus.net so we can get this raised again for further investigation.
04-08-2017 6:32 PM
Thanks. I have reported as a fault, so will wait and see what an engineer says.
08-08-2017 12:23 PM
Hi there, I'm just testing your line and will reply again shortly.
08-08-2017 12:26 PM
Your line is still dropping out, but not as frequently as it was on the 2nd:
The connection speeds look ok, the upload is a little lower than I'd expect:
Downstream Speed | 76.2 Mbps | ||||
Upstream Speed | 12.0 Mbps | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Interference Duration Longest Occurrence | From 18:00 to 18:15 | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Retransmission High | ||||
Time Stamp |
2017-07-26T12:30:00 |
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 72.7 | 55 | 20 | 14 | 49 | Available | -- | -- | -- | -- |
I'll update your fault ticket and get this passed through to our suppliers.
08-08-2017 7:15 PM
Thanks for the reply. Honestly I don't mind that the speed is a little low. I would happily take a speed decrease if it meant my internet would be more stable.
Hopefully this can be resolved soon!
09-08-2017 11:42 AM
I've updated the fault ticket, the next step is going to be an engineer visit.
09-08-2017 11:26 PM
My line used to drop at exactly the same time each day - when the central heating boiler switched on to heat the hot water. Have you compared the drop times with your central heating programming?
11-08-2017 6:30 PM
Hi. Yea that's one of the areas which I think could potentially be interrupting my connection. Did you manage to fix your problem, or find a solution?
My drop times are fairly close together, they don't always match the boiler times but i'm definitely keeping an eye on the situation.
