Internet down - Phone support closed
- Internet down - Phone support closed
19-08-2020 1:16 PM
Hi! Not sure where to turn. My internet went down 30 minutes ago and the phone support says it's too busy to take any more calls for the day.
1 REPLY 1
Re: Internet down - Phone support closed
20-08-2020 9:29 PM
Hi, any lights on the router, flashing, steady?
Can you 'see' your router at your PC, i.e. can you connect to the router even if not the Internet
What message do you see when you try to load a page?
Do you phones work?
Have you checked/substituted the ADSL filters near the phone sockets?
Good luck.
