Internet cuts out multiple times a week.
eriksm
The internet has been cutting out multiple times a week out of the blue, lasts about 5 minutes and then is back to normal like nothing happened. The hub flashes orange while it's happening.
4 REPLIES 4
MauriceC
Fixes: 17
Re: Internet cuts out multiple times a week.
Is your phone fed by an overhead cable by any chance?  Could well be a loose or corroded joint in the cable, so well worth a quick external check.
eriksm
Don't believe we have overhead cables, nothing looks loose either way.
Mustrum
Fixes: 73
Try dialling 17070 option 2? Is it quiet?
eriksm
Yes it's quiet.
