Internet Connection & WiFi Issues
pedleyclan
Our internet connection drops out on a daily basis and to be honest it's getting very irritating. We are paying for a service that we have to keep our fingers crossed will keep working and not drop out.
The WiFi signal has also dropped dramatically to what it originally was. Please tell us there is a reasonable reason for this
5 REPLIES 5
WillF
Fixes: 22
Re: Internet Connection & WiFi Issues
Hi @pedleyclan, sorry to hear of the problems with the connection. I've checked your line this found no issues. As per the graph below the connection is fairly stable as well.
If you've noticed a drop in wireless performance/signal, I'd recommend first running through our wireless performance guide here: https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
 Will
blake48
We are suffering similar frequent drop outs too.  I am noticing an increasing amount of similar posts, I would say this appears to be more a Plusnet issue that needs addressing, rather than individuals, since a growing number of us all seem to be experiencing the same issue.  Please advise, thanks
Fixes: 160
@blake48
Piggy-backing on other people's topics as you have done here (on FTTC) and here https://community.plus.net/t5/ADSL-Broadband/Can-t-contact-customer-service/m-p/1750059#M338124 (on ADSL) helps no one - especially you.  Please raise a topic for your problem on the appropriate board so that you can obtain the assistance you need.  Posting in two places is against the forum rules, whilst posting on other people's topics simply creates confusion.
Presuming that suffering from similar symptoms has the same one cause is an unwise move.
pedleyclan
It's very strange because it's happening daily. Most times it rectifies itself - as if it's just had a quick swig of coffee - but other times we have to restart the router (I nearly showed my age and called it a modem there 🙄)
Fixes: 160
Have you followed the WiFi guidance provided above? What do you see which makes you think the connection has dropped? The radius plot suggests that the uplink is very stable.
Which router are you running?
On the device you see as disconnecting what OS is it running and what WiFi card does it have? You’ll need to look at network settings.
