Intermittent failures after 4pm each day - since installation
mrterryparke
Since installation over a month ago, my Plusnet service has been failing intermittently after roughly 4pm every day. Everything works fine during the day.
We have had an Openreach validate the line and find no issues.  A new router proved to increase the frequency of failures, so reverted back to the original.  A new filtered power supply has been used and no local (in house) power fluctuations can be linked with the outages.
Plusnet havent been able to identify a fix and have not been proactive in managing this issue - only reacting when i call.
We had been working with BT for the past 18 months without issue.
In my limited knowledge, it feels like maybe a contention issue or something to do with the busier times of the day.
Anyone seen similar issues?  Suggestions on what Plusnet could do next?
Tags (1)
17 REPLIES 17
Legend
Fixes: 254
Re: Intermittent failures after 4pm each day - since installation
@mrterryparke Welcome to the forums. First question, as the possible remedies are  different - are you definitely on ADSL and not FTTC?
corringham
Seasoned Champion
Fixes: 16
When you say the service is failing, do you mean the DSL is dropping connection, or that it becomes unresponsive (e.g. devices report "no internet")?
Is it for a minute or two (while the connection restes) or for a protracted period (an hour or two)?
mrterryparke
I am on ADSL (i live in a small village), 900m from a green box, 4km from the nearest exchange i believe.
The connection seems to drop, the Plusnet router starts flashing orange and will go through its reconnection process for approx 3mins. It will then reconnect (light turn blue) and all is working again.
Some days it then works for approx 10mins before failing again.  sometimes it fails a hour later.
But everyday its generally fine up to 4pm....and after that time it is a lottery for how long it works for, until around 10pm.  Not sure after that point as i am in bed.
Has been failing like this on a daily basis since installation.
Legend
Fixes: 254
@mrterryparke Sorry - I had to ask the question, but some people on FTTC post on this board, and then when we attempt to help them, they complain our suggestions don't work - they won't, because of the different technology involved.
From what you say in your original post, it appears to be a failure in the BTOR network. It would be useful if you could get PN to send you a copy of the 'Visual Radius Log' to confirm this. The behaviour you mention is not contention - it is network related, but only the VR log will confirm this.
mrterryparke
Here is a VR from 24th Feb
mrterryparke
other info from my plusnet ticket
** INTERNAL **
KBD
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 74.7 Mbps
Upstream Speed 10.7 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Radio Frequency Ingress Detected
Cross Talk Detected
Estimated Line Length In Metres 682.9
Upstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From02:15to02:30
Interference Location Unknown
Interference Observed In Days 9
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2021-02-11T13:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 66.2 Mbps 75.1 Mbps 71.1 Mbps
Up Stream Line Rate 9.3 Mbps 10.8 Mbps 10.5 Mbps
Up Time 463.0 Sec 900.0 Sec 893.0 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-02-24T13:09:13Z 2021-02-24T13:24:13Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
GEA Test Detail
Circuit ID NA Service ID BBEU39145189
Legend
Fixes: 254
Thanks for that - it proves what I have said - a network problem, nothing to do with contention at all.
By the way, that KBD indicates you are on FTTC - Not ADSL.
mrterryparke
ah,
i just know i am on a copper link to my house, thanks for looking and advising.
Legend
Fixes: 254
FTTC = Fibre To The Cabinet, with copper from the DP to your house.
mrterryparke
at least ive learnt something, cheers
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
escsanji
Having very similar problem, so far no real solution from Plusnet, will be interested to see if either our situtaion improves and how
mrterryparke
Plusnet techies have advised they have made config changes today.  Will wait and see what happens tonight
Legend
Fixes: 254
Good to hear, @mrterryparke  - but I assume they haven't said what they are, which is not useful?
