Intermittent connection dropouts - how to troubleshoot?
ad441
Been suffering from intermittent dropouts in my fibre connection for last week or so. Connection speed otherwise fine. What's the best way to go about troubleshooting this?
12 REPLIES 12
bobminors
Re: Intermittent connection dropouts - how to troubleshoot?
Which kind of dropouts?
  • Modem disconnecting from the outside world and reconnecting itself
  • PC WiFi disconnecting from the modem
  • Stutter / Lost frames when streaming
  • Something else?
Chris
Legend
Fixes: 169
There's some troubleshooting guides here: http://www.plus.net/support/broadband/bbfaults/
We're not seeing many disconnections from here:
ad441
Sorry for slow reply. Everything seems set up right on router/with cables, but I've had the home phone disconnected for a while - is that likely to cause connection dropouts? Will try reconnecting it.
Otherwise is there any sort of log I can call up on the computer (Windows 10), that might show the problem?
ad441
Still having problems with this. Am wondering if the problem is Windows 10 update/Technicolour TG582n as discussed here.
https://community.plus.net/t5/Fibre-Broadband/Recent-update-of-Windows-10-amp-router-problem/td-p/13...
If so would like to know how to resolve.
richusx
I'm having the same issue here. This started around last Monday (24th October). Really annoying when in-game, around every 30-60 seconds I get a horrible ping spike which rolls me back (packet loss?) and at the same time voice service lags out as well. Any clue how to fix this?
Chris
Legend
Fixes: 169
@ad441
Leave that with me and I'll see if I can get it pushed through to you.
@richusx
I'll do the same for yours
richusx
@Chris Any updates?
Chris
Legend
Fixes: 169
This has been pushed to your router.
ad441
Thank you - will report back if I get anymore dropouts - so far none, so am hoping problem is fixed, but haven't been on internet much today.
richusx
@Chris Thanks you so much! Seems to be fixed for me as well.
Any idea what was causing this?
Chris
Legend
Fixes: 169
It's a bug that happens with certain versions of Windows and the Technicolor router. There's quite a bit of detail here https://community.plus.net/t5/Broadband/198-18-1-x-address-problems/td-p/1171169
Joshmmurphy
Hey, I think I'm having the same problem. I believe it started when there was a windows 10 anniversary update back in October/November time. Ever since then both of our windows 10 laptops have been having browser trouble. The connection just keeps dropping out. Are you able to try what you have for the guys above? Many thanks, JoshMMurphy
