Intermittent Connection Dropping
- Intermittent Connection Dropping
04-10-2018 5:28 PM - edited 04-10-2018 5:33 PM
Hi
Since some time today, every 10 minutes or so my connection totally drops out for a minute or so. Download and upload speeds are still nominal with no high ping.
I am in the IP3 8 postcode area for anyone else having similar issues.
My ping test during one of the disconnects shows bellow.
Have restarted router and still no help, using ethernet cable.
ping www.google.co.uk -n 30
Pinging www.google.co.uk [216.58.206.67] with 32 bytes of data:
Request timed out.
Reply from 192.168.1.254: Destination net unreachable.
Request timed out.
Request timed out.
Reply from 216.58.206.67: bytes=32 time=10ms TTL=55
Reply from 216.58.206.67: bytes=32 time=11ms TTL=55
Reply from 216.58.206.67: bytes=32 time=18ms TTL=55
Reply from 216.58.206.67: bytes=32 time=13ms TTL=55
Reply from 216.58.206.67: bytes=32 time=14ms TTL=55
Ping statistics for 216.58.206.67:
Packets: Sent = 30, Received = 27, Lost = 3 (10% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 18ms, Average = 11ms
Re: Intermittent Connection Dropping
04-10-2018 7:12 PM - edited 04-10-2018 7:14 PM
Moderator's note by Dick (Strat): Post released from Spam Filter.
Sorry but we don't know why the automated filter does this.
04-10-2018 10:01 PM - edited 04-10-2018 10:03 PM
Hi @tommygunyeah,
We are sorry to hear you are experiencing an issue with your connection. I have a checked your connection and there definitely seems to be something out of place somewhere as we can see more drops in connection than we would like. Although our tests aren't picking up exactly what's causing the issue, we would need to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop.
This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If the problem still persists from here, please report the issue here and let us know when you've completed it.
07-10-2018 1:54 PM
Honestly, the issues seemed to have stopped and I haven't seen any issues since. Nothing has changed in my wiring in my home.
08-10-2018 11:33 AM
