Intermittantly not being able to connect to the internet
BereniceH
I wonder if anyone can help. I've raised this issue with PN several times over the last year, and thusfar they haven't been able to resolve my issues Sad
My connection can be fine for weeks or even months, and then I start having problems again. I don't loose synch but my connection to the internet on every device (laptops, desktop on wired connection, central heating gateway, CCTV, Amazon Echo etc) fails. I can refresh a webpage 10 times, and it MIGHT load (or partially load) once.
Everything has been changed. I've had 2 new routers, bypassed the faceplate and gone into the master socket, changed microfilters, disconnected all phones etc etc etc and nothing has made any long term difference.
PlusNet have run line checks which show no problems and referred it to Openreach at least twice but they say they are unable to find a problem. When it's working normally, my connection is totally stable, no disconnects and exemplary ping and speeds.
My latest episode started on Sunday morning. I raised a fault and was told it was going to be referred to the back room, but thusfar I've not had an update to my ticket, I have had no useable connection for 3 days now and I'm starting to get a bit tetchy!
The only other thing that I can think of that might be relevant is that we're on static IP
HEEEEEEEEEEEEEEEEEELPPPPPPPPPPPPPPP!!!!
Fixes: 46
Re: Intermittantly not being able to connect to the internet
I've just sent an update on the ticket.
Can you try connecting to the router over a cabled connection and see if the same issue happens?
 Adam Walker
BereniceH
this bit Adam!!
I have currently swapped back to router#1 and all is working perfectly, but that of course could be coincidence. I am just about to go back to router#2 to see what happens!
BereniceH
and of course router#2 is now working perfectly as well .... but for how long is the question!!!
Fixes: 46
That sounds really promising.
Let us know how things are on your side after a few days and I'll see what your connection logs look like.
 Adam Walker
BereniceH
LOL I prefer problems to have an explainable resolution!!
Fixes: 46
I hear you, we can't always explain the exact reason for such a problem in retrospect but the good news is that your connection is still stable.
 Adam Walker
BereniceH
agreed... I'll close the ticket...... until the next time!
Fixes: 46
Thanks a lot, do shout up if you have any more issues.
 Adam Walker
BereniceH
And back down the snake.......
no connectivity this morning again - I suddenly realised it seems to happen (at least the last 3 times) overnight sat into Sunday.
blue light still showing synch
swap to modem #2 and problem fixed
swap to modem #1 problem reapoears
swap back to #2 and it's ok at the moment.
i don't think this is a modem issue here bearing in mind I'm now on the 3rd one. I suspect it's actually something to do with which modem rack at plusnet I end up connected to. The details (i.e. User name) on both are identical.
of course historically my first action was to reset and then reboot the router!
please can this go to the back room as I was promised last week?
BereniceH
............ now this is weird....
I've just noticed that one of my wifi CCTV cameras was still connected (and recording) when nothing else was able to connect.
BereniceH
now back on #1 and connection good
what IS going on?
BereniceH
today's variation... I can't access the NatWest portal! I've tried 3 PCs and an iPad. Edge, Chrome, Safari and IE
When I connect via my phone hotspot it works perfectly.
