Intermittantly not being able to connect to the internet
BereniceH
I wonder if anyone can help. I've raised this issue with PN several times over the last year, and thusfar they haven't been able to resolve my issues Sad
My connection can be fine for weeks or even months, and then I start having problems again. I don't loose synch but my connection to the internet on every device (laptops, desktop on wired connection, central heating gateway, CCTV, Amazon Echo etc) fails. I can refresh a webpage 10 times, and it MIGHT load (or partially load) once.
Everything has been changed. I've had 2 new routers, bypassed the faceplate and gone into the master socket, changed microfilters, disconnected all phones etc etc etc and nothing has made any long term difference.
PlusNet have run line checks which show no problems and referred it to Openreach at least twice but they say they are unable to find a problem. When it's working normally, my connection is totally stable, no disconnects and exemplary ping and speeds.
My latest episode started on Sunday morning. I raised a fault and was told it was going to be referred to the back room, but thusfar I've not had an update to my ticket, I have had no useable connection for 3 days now and I'm starting to get a bit tetchy!
The only other thing that I can think of that might be relevant is that we're on static IP
HEEEEEEEEEEEEEEEEEELPPPPPPPPPPPPPPP!!!!
16 REPLIES 16
adamwalker
Fixes: 221
Re: Intermittantly not being able to connect to the internet
I've just sent an update on the ticket.
Can you try connecting to the router over a cabled connection and see if the same issue happens?
 Adam Walker
BereniceH
this bit Adam!!
I have currently swapped back to router#1 and all is working perfectly, but that of course could be coincidence. I am just about to go back to router#2 to see what happens!
BereniceH
and of course router#2 is now working perfectly as well .... but for how long is the question!!!
adamwalker
Fixes: 221
That sounds really promising.
Let us know how things are on your side after a few days and I'll see what your connection logs look like.
 Adam Walker
BereniceH
LOL I prefer problems to have an explainable resolution!!
adamwalker
Fixes: 221
I hear you, we can't always explain the exact reason for such a problem in retrospect but the good news is that your connection is still stable.
 Adam Walker
BereniceH
agreed... I'll close the ticket...... until the next time!
adamwalker
Fixes: 221
Thanks a lot, do shout up if you have any more issues.
 Adam Walker
BereniceH
And back down the snake.......
no connectivity this morning again - I suddenly realised it seems to happen (at least the last 3 times) overnight sat into Sunday.
blue light still showing synch
swap to modem #2 and problem fixed
swap to modem #1 problem reapoears
swap back to #2 and it's ok at the moment.
i don't think this is a modem issue here bearing in mind I'm now on the 3rd one. I suspect it's actually something to do with which modem rack at plusnet I end up connected to. The details (i.e. User name) on both are identical.
of course historically my first action was to reset and then reboot the router!
please can this go to the back room as I was promised last week?
BereniceH
............ now this is weird....
I've just noticed that one of my wifi CCTV cameras was still connected (and recording) when nothing else was able to connect.
BereniceH
now back on #1 and connection good
what IS going on?
BereniceH
today's variation... I can't access the NatWest portal! I've tried 3 PCs and an iPad. Edge, Chrome, Safari and IE
When I connect via my phone hotspot it works perfectly.
BereniceH
This problem is still ongoing with 2 periods of 5 days each where no connection in or out is possible. After 20 years as a customer of PlusNet/Force 9 I am frankly dismayed at the level of customer service. I get asked the same questions over and over again.....can NOBODY be bothered to read the tickets?
I have been offline since last Sunday (again, it was a Sunday, as it is 90% of the time when it starts)
Traceroutes on LAN show quite clearly that I am getting past the router and then the connection stalls. I am unable to connect to my CCTV, my heating, any of my smart devices (with the exception of 1 Smartfrog camera) or my router externally.I never loose synch, nor do PlusNet see any disconnections.
Does anyone out there have any suggestions?Please Please Please!!!
I am on my 3rd modem, all cables/filters have been changed at least twice, I've used the master socket....sometimes rebooting the router will clear it, sometimes not. It makes no difference if I disable the wifi.
BereniceH
The have now changed my fixed IP to a new one..... fingers crossed
