Intermittant speed drops
mac101
I have been with Plusnet for over 4 years now and this is the first problem I have had with my connection. I have just come back from holiday during which my router was shut down. During the past 4 days my speeds have varied from 70.43/17.16 to 7.39/9.05. These speed changes are happening from minute to minute at all times of the day. I have disconnected my set-up and plugged a different router/ cables/computer and am still getting these sudden speed changes. I have used the BT Wholesale Speed check and also Speedtest and both give similar results.
Could you please run a line check for me.
Thank you
mac
5 REPLIES 5
EmilyD
Fixes: 111
Re: Intermittant speed drops
Hi @mac101,
I'm sorry that your speeds have been up and down and for any inconvenience that this has caused you. I've tested your line, however the test hasn't picked up the cause of the problem from here and indicates a stable connection at 79.9mbps down and 20mbps up:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 457.6
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream 3dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-09-12T14:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 79.9 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 0.0 Sec 900.0 Sec 209.4 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-09-25T12:52:56Z 2019-09-25T13:07:56Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
So that we can determine the best next steps towards resolving this, please can you confirm whether this is solely affecting wireless connections or if wired connections are affected too?
 Emily D
mac101
Thanks for the quick reply Emily,
Both wired and wireless are affected. The speeds are up and down all the time, 70/18 one minute 10/8 the next.
TheMightyAJ
Fixes: 105
Hi @mac101,
Thanks for confirming this. I would strongly recommend setting your router up within the test socket if it isn't already. For reference, we have a guide on how to do this here. I'd also recommend going through our online troubleshooting guide to see if any of the recommended steps help to resolve the issues you're experiencing. This can be found here.
Please let us know how this goes and we'll be happy to pick this up for further investigation if the recommended guides don't resolve the fault.
 Alex H
mac101
I traced the fault to an old powerline adaptor I was using on my network. I cant complain as I have been using it for 5/6 years, but is good to see my speed back up to 71/18 again.
Thanks for your advice Plusnet Help Team!
SammyM
Fixes: 53
Heelo @mac101,
We are happy to hear your speed is back where it should be. Please don't hesitate to drop us a message if you need any further assistance as we are always happy to help.
 SammyM - Sheffield Team
