Intermittant red light on router
- Intermittant red light on router
06-08-2018 11:08 AM
Every so often when I am browsing I lose connection and red flashing light comes up on the router.
After a few minutes the blue light comes on and the connection is restored.
This never happened with my previous provider. Is there a problem with my PlusNet router?
Re: Intermittant red light on router
06-08-2018 4:40 PM - edited 06-08-2018 4:41 PM
Hi @stefanjan,
I'm sorry to hear that your connection is dropping. I can see the drops on your connection log here:
However, testing your line isn't picking up the cause of this issue. For reference, today's test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 29.6 Mbps | ||||
Upstream Speed | 5.4 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 969.4 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed on Week Days | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 08:45 to 09:00 | ||||
Interference Location | Other | ||||
Interference Observed In Days | 13 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Retransmission Low | ||||
Time Stamp | 2018-07-24T16:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 29.0 Mbps | 35.5 Mbps | 32.6 Mbps |
Up Stream Line Rate | 4.7 Mbps | 5.6 Mbps | 5.4 Mbps |
Up Time | 483.0 Sec | 900.0 Sec | 898.2 Sec |
Retrains | 0.0 | 4.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-06T15:10:03Z | 2018-08-06T15:25:03Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please can you run through our troubleshooting guides here. If the troubleshooting checks don't resolve the issue, please report it here and let us know when you've completed it - we'll then be able to investigate this further for you.
19-08-2018 9:00 PM
The problem seemed to go away after your intervention but it has now become more frequent again.
I never had this issue with Talktalk.
It is not practical to attach the router to the main BT box as that is in the hall. My desktop PC is hardwired to the router which is on BT extension. A network cable also connects all the devices in our living room.
Connecting the router to the main BT plug would require running new network cables all over the house which is not practical.
20-08-2018 11:36 AM
Hi @stefanjan,
I have ran some checks on your line for you once again. The speed checks are looking fine, but I can once again see drops in your logs. Please can you confirm if you are still connected to the test socket for me please.
If you didn't do this before, you can find a guide on how to do this at https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
