Interleaving
HoboWithAShotgu
Interleaving
Hello, is it possible to check if my line has interleaving turned on or off? Is it also possible to set it to off (if it's already on). Thank you.
1 REPLY
Fixes: 46
Re: Interleaving
Hi Hobo-With-A-Shotgun,
Interleaving has been applied on the lowest setting, however it's not something we can turn off I'm afraid as it part of DLM (dynamic line management) which is entirely automated for a fibre connection.
 Adam Walker
