Interleaving removal request
- Re: Interleaving removal request
19-12-2017 11:58 AM
Hi there.
I've got what appears to be a very stable line and get great speeds as I'm only 30 meters from my ftcc cabinet but still get high ping, could i be put on fastpath ie. having interleaving turned off on my line please.
Cheers Andrew
19-12-2017 1:37 PM
Hi Andrew. We've got no manual control over interleaving for fibre lines I'm afraid.
With that said, it looks like interleaving might be off:
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
19-12-2017 2:02 PM
hi thanks , could you look at these numbers , do they seem correct for a 30 meter line , my pings are in the 50 to 60 range for bbc.uk, they used to be 10 to 15 ?
6. Data rate: | 19999 / 79903 |
7. Maximum data rate: | 33563 / 92245 |
8. Noise margin: | 14.7 / 9.3 |
9. Line attenuation: | 12.5 / 9.7 |
10. Signal attenuation: | 12.4 / 9.7 |
Cheers Andrew
