Integrated modem and router
- Integrated modem and router
07-08-2015 8:38 AM
Hi. I currently have Plusnet ADSL with their supplied router, and it works just fine.
I am now thinking of upgrading to PN's fibre broadband, but do NOT want to have the separate Openreach modem and thus I won't be able to use PN's supplied router. After doing a bit of reading, I'm leaning towards getting a TP-LINK TD-W9980. If I understand correctly, this will be compatible with my existing ADSL, but will also work when I upgrade to fibre without needing the pesky Openreach box.
Is this all correct?
Also, when I go to fibre, will I still need to have my master socket updated as I would if I were having the Openreach modem fitted? Or can I use my existing socket with a microfilter?
Message 1 of 9
(1,602 Views)
8 REPLIES 8
Re: Integrated modem and router
07-08-2015 9:47 AM
Self install still isn't an option so a BT Engineer will attend and change the faceplate
Re the router - it will work but have you read http://forum.kitz.co.uk/index.php/topic,14436.0.html and the linked discussion threads
Message 2 of 9
(783 Views)
07-08-2015 4:59 PM
For most people a separate modern is the better solution as if you are using a WiFi router it allows you to position it for better coverage than wedged against an outside wall.
Message 3 of 9
(783 Views)
07-08-2015 5:02 PM
I've been using a TD-9980 for a while now, very stable and no complaints about it from me.
Message 4 of 9
(783 Views)
07-08-2015 6:11 PM
A sub £65 Billion 8800NL works well for me with about a dozen wifi connections plus umpteen Ethernet ones!
Geoff,
York.
York.
Message 5 of 9
(783 Views)
07-08-2015 9:27 PM
Thanks for the replies so far. Keep em coming.
Btw my master socket is in a good position for wireless coverage, so no need to have my router any distance away. So integrated solution should be fine from that point of view.
Message 6 of 9
(783 Views)
07-08-2015 11:14 PM
Home Hub 5 Version B works well as an all in one.
Message 7 of 9
(783 Views)
08-08-2015 10:08 PM
I'm using a DrayTek 2760 modem router (the non-Wi-Fi version) and devolo 1200+ ac powerline adapters. I have one positioned at the rear of the house on the ground floor and one on the 1st floor at the front of the house. I like this because it sets me free from worrying about a router's Wi-Fi capabilities and it's flexible since I can position the units where I need them
Message 8 of 9
(783 Views)
09-08-2015 8:52 AM
I have a Asus DSL ac68u ,although its in the higher price range it has cured the problems i was having ,and wifi is excellent all over the house
Fantastic single box option
Message 9 of 9
(783 Views)
