Installed today FTTC and speed test reporting no better than adsl
rodtrotter
I have had my FTTC installed today the openreach guy done a speed test from the modern and it was reporting download of 80 and upload of 20  but when I run a speed test it's showing 3.75 download and 1.5 upload and when trying to play on line games the lag is very bad I know the line will take time to settle but this seems very slow for FTTC  could this be down to the router the openreach guy did say that the router is a pile of c#€p. Shocked
Fixes: 58
Re: Installed today FTTC and speed test reporting no better than adsl
Probably this hasn't updated https://portal.plus.net/my.html?action=data_transfer_speed
However the upstream is still too low - are you checking wired or wireless
rodtrotter
Hi running speed test wired will do another test when I get in from work thanks
rodtrotter
That link you posted is reporting line speed of 77.4 wow
What is causing the low speed  Undecided
Can you try restarting your router (not the BT Modem, the PlusNet router)
It's possible that  your profile has been updated, but not yet in use, needed a router restart.
rodtrotter
ok got in from work ran a speed test still the same done a fatory reset still the same if this is what i am going to get i will go back to adsl I am not paying more for less.
can someone from plusnet please take a look at this for me.
Fixes: 4
Your speed profile was updated to the new speed on the 14th, but your modem was last reset on the 13th.  Give them a reboot and you should see your new speeds.
Kelly Dorset
Broadband Service Manager
rodtrotter
i done a router reset earlier today do you mean reset the openreach modem ?
Terranova667
No do not reset the modem that can cause DLM to act and slow your speed down, reset the router only
rodtrotter
seem to be getting somewhere now.
my network adapter was holding the speed down i have reset it and pow its looking good  Cheesy Cheesy Cheesy
Fixes: 12
Quote from: Terranova667
Kelly said reset the "modem".
