Installation day
elevonic
Installation day
Hi, I will be having plusnet fibre installed next week, hopefully. I'll be changing from BT infinity fibre. The question I have is about the actual process. I already have an openreach modem installed, so why do they need to come in and swap it over? Also, will I need to leave my computer 'unlocked' so they can access the router and set it all up? I wont be in but somebody else will be. Thanks
7 REPLIES 7
AndyH
Re: Installation day
If this is just a migration, then don't expect an engineer to turn up as the migration is done remotely. Unfortunately, Plusnet have not been good at communicating this...
elevonic
I presume it is just a migration, I've sent Plusnet the MAC code.
AndyH
Basically, Openreach will not turn up for a migration. If an end user does not have a modem, then Plusnet have to first wait for the migration to complete and then book it as a fault so an engineer can come out and provide a modem.
In your case, there should be a brief outage and then the service will work again (hopefully with Plusnet). The only change you should need to make is obviously the change the login details on your router. Have you received a Plusnet router?
elevonic
Ok, thanks for your help, saved a wasted day off!
MatthewWheeler
Fixes: 479
As AndyH has stated you dont need to wait in as it's all done remotely.
Once the new ordering system is in place this should be communicated better.
 Matthew Wheeler
elevonic
Went live yesterday, although it should have been today, good job I was (just) out of contract with BT. I still received a message saying an engineer will be visiting right up until yesterday.
AndyT
Hi elevonic,
Glad to see the migration has completed successfully and your connection is working well.  Sorry about the text message, as Matthew said this is something we're aware of and it should be resolved when the new ordering system is implemented
