Infrastructure issue (cable fill) but Openreach won't fix it - thoughts welcome
- Infrastructure issue (cable fill) but Openreach wo...
Re: Infrastructure issue (cable fill) but Openreach won't fix it - thoughts welcome
26-04-2019 8:39 AM
26-04-2019 8:41 AM
26-04-2019 10:15 AM
26-04-2019 6:57 PM
26-04-2019 8:02 PM - edited 26-04-2019 8:03 PM
I too am thinking of going for a bizz one, more so for the ability to tweak the DNS.
Let us know of you get more than 12 14 days!
edit. Doh I meant 14, silly me
26-04-2019 9:32 PM - edited 26-04-2019 9:33 PM
Firmware version: SG4B1B0092B4
Firmware updated: 19-Apr-2019
26-04-2019 10:28 PM
For reference:
Firmware version: SG4B1000B540
Firmware updated: 02-Mar-2019
Data rate: 6.21 Mbps / 37.49 Mbps
Maximum data rate: 6213 / 36814
Noise margin: 5.7 dB / 2.5 dB
Network uptime: 9 Days, 11 Hours 1 Minutes
System uptime: 9 Days, 11 Hours 35 Minutes
I've had no drops in the connection, nor any other known issues
(then should I get a BH6, I might put this one upstairs as a new slave router;))
28-04-2019 9:01 PM
Maximum data rate: 6213 / 36672
Noise margin: 5.7 dB / 2.4 dB
Network uptime: 11 Days, 9 Hours 33 Minutes
System uptime: 11 Days, 10 Hours 11 Minutes
It's still holding on to a <3.0dB SNR
If it gets to 15 days, I may drop back to the H1 to see what the line is doing (can run routerstats on the H1)
30-04-2019 1:10 PM
Maximum data rate: 6206 / 37812
Noise margin: 5.5 dB / 3 dB
Network uptime: 13 Days, 1 Hours 36 Minutes
System uptime: 13 Days, 2 Hours 14 Minutes
Not looking too bad.
Guess the H6 might do a warm restart tomorrow, then if I feel like it, I may put the H1 back online as a comparison
(and run routerstats on it to see if the noise margin is better, though it still looks erratic)
01-05-2019 3:57 PM
Not restart as yet....
Maximum data rate: 6213 / 37774
Noise margin: 5.6 dB / 3 dB
Network uptime: 14 Days, 4 Hours 29 Minutes
System uptime: 14 Days, 5 Hours 7 Minutes
So, is it the better router, or can the Hub One now cope....?
02-05-2019 10:03 PM
Ok... So the h6 never actually restarted
Maximum data rate: 6160 / 36695
Noise margin: 5.3 dB / 2.4 dB
Network uptime: 15 Days, 10 Hours 33 Minutes
System uptime: 15 Days, 11 Hours 10 Minutes
There were some events that would have been around the 14 days uptime
13:27:13, 01 May. ppp1:TR69 ConnectionRequest Failed
13:27:12, 01 May. ppp1:TR69 ConnectionRequest: processing request from ACS
11:25:17, 01 May.ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
11:25:16, 01 May. ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
11:25:16, 01 May. ppp1:TR69 receiving InformResponse message
11:25:15, 01 May. ppp1:TR69 event found : 4 VALUE CHANGE
11:25:15, 01 May. ppp1:TR69 event found : 2 PERIODIC
11:25:14, 01 May. ppp1:TR69 sending Inform message
11:25:12, 01 May. ppp1:TR69 event found : 4 VALUE CHANGE
11:25:12, 01 May. ppp1:TR69 event found : 2 PERIODIC
11:25:11, 01 May. ppp1:TR69 sending Inform message
11:25:09, 01 May. ppp1:TR69 creating new session with ACS
06:39:06, 01 May. ppp1:TR69 ConnectionRequest Failed
06:39:06, 01 May. ppp1:TR69 ConnectionRequest: processing request from ACS
04:52:33, 01 May. ppp1:TR69 ConnectionRequest Failed
04:52:33, 01 May. ppp1:TR69 ConnectionRequest: processing request from ACS
04:38:59, 01 May. ppp1:TR69 ConnectionRequest Failed
04:38:59, 01 May. ppp1:TR69 ConnectionRequest: processing request from ACS
(fwiw, the value change used to drop the connection, since the removal of the blue beans it maintains the connection)
But the SNR is still erratic (can't monitor atm) from around 2.2dB to 3dB (that I've seen) although gaming (inc Discord) and streaming are fine afaik.
And a GEA test from 17 April wasn't showing any issues (voice line test was not run).
Though a GEA test today came back with interference daily from 12:30 to 07:00 at my end...?
For anyone interested, the GEA continues to show high retransmission, but its stated that it usually comes off with time
btw, thanks BD for the ticket;)
Is it possible for PN to get OR/BT to 'up' the dsl checker info now?
(or do I have more chance of swimming on the moon?)
03-05-2019 10:14 AM
03-05-2019 11:12 AM
Thanks @Beyhive
fwiw, the router looks like it's going to maintain a connection for 16 days!!
DSL uptime: 15 Days, 23 Hours 47 Minutes 50 Seconds
Maximum data rate: 6213 / 37778
(I might buy it a birthday cake)
05-05-2019 8:46 PM
For anyone who's interested....
Maximum data rate: 6213 / 36990
Noise margin: 5.6 dB / 2.6 dB
Network uptime: 18 Days, 9 Hours 18 Minutes
System uptime: 18 Days, 9 Hours 55 Minutes
Download Speed (Mbps): 35.52
Upload Speed (Mbps) : 4.98
Ping Latency (ms): 72
(above over wifi)
05-05-2019 9:08 PM
Well my bt business hub 6 rebooted after the requisite 14 days on the dot, so the business firmware must be different to the consumer one😕
