Increasing Line Profile Causing Router To Disconnect / TV Pictures To Break Up
- Re: Increasing Line Profile Causing Router To Disc...
09-01-2018 10:11 AM
My line profile when I joined Plusnet was around 24/10, since then I know there has been a relaxing of error correction which increased my profile to 28/2, then there was the increase in the upload speed, which gave me a profile initially of 28/5.5, but since then things have gone crazy with the profile increasing almost daily, yesterday reaching 37/4.5. At the same time my Router has experienced more and more disconnects and my internet TV channels have experienced more and more break-ups.
Just chatted to Online Chat who says there is no problem with line check, and says there will be a £65 charge for engineer if they find no fault outside my house, wouldn't listen to me when I pointed out that nothing in my premises could cause such a dramatic profile change. The problem I have is that the engineer may well not find a fault at the time he checks.
Can someone help please? Surely the line profile is the problem? I am on 24/10 broadband, it seems impossible for the line to work properly at 37mbps, I am quite some distance from the cabinet.
Re: Increasing Line Profile Causing Router To Disconnect / TV Pictures To Break Up
09-01-2018 11:08 AM
Sorry last few words of post should be 40/10 broadband not 24/10!!
09-01-2018 11:36 AM
Same issue as myself. Check out my thread:
https://community.plus.net/t5/Fibre-Broadband/Downstream-SNR-Target-Reset-to-6dB-please/td-p/1495199
09-01-2018 11:41 AM
Yes seems like same problem, can someone have a look at this please, and before anyone asks the line check shows no fault AND the Router is plugged into the master socket AND my computer is wire connected to my Hub
09-01-2018 12:09 PM
Just checked BTW speed test current 35.19/5.84 and that was from a wifi connecte laptop so actual is faster than that. max achievable speed 36.19 and 10
09-01-2018 12:57 PM
Unfortunately there is no way round it other than changing router to one which allows the line speed to be limited
I had the same problem and using my Billion 8800NL I sorted it with the speed limited to about 42Mb/s
However since that the G.INP setting have been changed by the automatic system in the cab and it is now relatively stable at 49Mb/s although that may have been down to reduced crosstalk
the fact that a new fibre optic cable has been laid past my front door feeding some areas which presently can't get FTTC is possibly not relevant although it may well have reduced the crosstalk in the present main copper line by getting some of the users off it
09-01-2018 3:35 PM
Is there a cap to reduce speed from 76mbps to 40mbps depending on if you are on unlimited fibre extra or not? It is impossible for my broadband to be sinking at 37mbps on 40/20 broadband, I am too far from the cabinet to allow that unless there is some sort of a problem - still showing on BTW speed test as max speed 37.21/10
09-01-2018 10:27 PM - edited 09-01-2018 10:28 PM
Connection just dropped again, first time I have noticed today.BTW speed tests showing 35.21 / 5.33, max achievable 36.22 / 10 . I suspect there have been more disconnects through the day. There was some break up of TV pictures early evening.
These results were on my wifi connected laptop some speeds greater than this.
10-01-2018 10:32 AM
Pulled the log for around 10:15 disconnect last night:-
22:14 PPP LCP Send Termination Request (User Request)
22:14 PPoE is down after 222 minutes uptime
22:14 PTM over DSL is down after 222 minutes uptime
22:15 CWMP: Initialising Transaction for event Code 4 VALUE CHANGE
22:14 CWMP: Session start now. Event code(s) 4 Value Change
22:14 CWMP: Server URL: http://dpdtnhdpm.bt.mo ; connecting as user : ACS username
22:14 CWMP: session closed due to error: Could not resolve host
..........the last 4 lines then keep repeating until I press the reset button on the hub, then it starts up as normal.
While I was in the log I noticed dozens of:-
IN{ BLOCK (number) spoofing protection (IGMP followed by code)
................what is this????
Current BTW speeds 35.17 / 4.72, max achievable 36.22 / 10 via wifi
10-01-2018 10:39 AM - edited 10-01-2018 10:51 AM
Someone else having same problem? See 'CWMP Connection Failure' under Fibre Broadband forum.
10-01-2018 11:14 AM
Just had another increase in speed (BTW Speed Test via wifi) : 36.26 / 4.8 interesting because its wifi AND test shows max achievable is 36.22, what's going on?
11-01-2018 8:31 AM - edited 11-01-2018 8:31 AM
No disconnects in the last 24hours!! Speed more stable 36.16 / 4.86 via wifi, 36.22 / 10 max achieveable. Still getting a lot of 'spoof protection' from hub log.
12-01-2018 9:37 AM
Line seems to have stabilised, no disconnects, speed now fairly constant 35.53 / 5.86, interesting to see upload speed has increased with a corresponding decrease in download speed. Keeping my fingers crossed!!
13-01-2018 1:07 PM
Just checked BT Broadband Availability Checker, it states VDSL Range A (Clean) = 34.1 high, 22.4 low. so how come my last BTW speed test was almost 37? Is this possible?
The good news is I haven't had any router drop outs or picture break ups for a couple of days.
