Increased Latency and laggy connection
- Increased Latency and laggy connection
08-09-2015 9:12 AM
Mornings guys,
The past couple of days I've noticed increased latency on my TBB graph, web browsing is noticeably laggy and speed tests are all over the place - They end up roughly around the 36Mbps mark (which I'd expect for my 39Mbps sync) but while the test is running the needle jumps all over the place.
I gave the router + modem a reboot last night but it's made no difference, before I raise a fault I'd like to see if the guys here can see any issues with my line that could easily be fixed.
BQM graph - http://www.thinkbroadband.com/ping/share/b0bfc1f63c4e986870fff5707f8a1c6a-08-09-2015.html
Thanks in advance
EDIT: To clarify no devices are connected overnight to cause that sort of latency by downloading etc
Thanks in advance
Message 1 of 3
(565 Views)
2 REPLIES 2
Re: Increased Latency and laggy connection
08-09-2015 11:20 AM
Nothing obvious on the tests I've been through, the sync is fine, the line isn't dropping much and the profiles are where I'd expect.
Does the problem happen at certain times of the day? I ask because your usage can be quite high and I want to try and eliminate the problem happening while you're downloading or uploading.
Message 2 of 3
(345 Views)
08-09-2015 11:44 AM
Hi Chris,
Nope it seems pretty random, I've noticed it even when I'm the only one in the house / connected (checked the router to confirm this) but the BQM graph shows constant, identical latency which I wouldn't expect to see when downloading, or even when streaming Netflix I notice minimum latency shoots up, as per this graph...
http://www.thinkbroadband.com/ping/share/0c5b97e451c321e58b6aa10bc1e9e168-06-09-2015.html
Message 3 of 3
(345 Views)
