Increase in BT profile
- Increase in BT profile
Re: Increase in BT profile
15-01-2015 10:07 AM
@Andy all iknow is mattyc changed my plusnet profle and the BTW one dropped, my plunest profile is still at 58Mb something went screwy
15-01-2015 11:18 AM
15-01-2015 12:06 PM
15-01-2015 12:19 PM
From the visual radius graph below, you can match the timestamps on the data I've attached to the resyncs on the line.
So the disconnection you can see right at the start of the graph was the one that resynced you at 59996, giving a profile of 58000. The single disconnection at 11.30am yesterday was the one that synced at 52100, giving the current profile of 50400. There were also 4 disconnections within a minute at around 4.33pm, these did not impact the profile or sync.
15-01-2015 12:21 PM
15-01-2015 12:56 PM
anyway you say changing profiles on your side doesn't cause sync drop but it clearly did the graph shows the drop at the time my plusnet profile was changed, Something must of went wrong has anyone talked to BTW as i asked to see what happened is there going to be an investigation of any kind or is it going to be brushed under the carpet like everything else.
@Melancholie not sure what you getting at with your response
15-01-2015 1:08 PM
15-01-2015 1:12 PM
15-01-2015 1:16 PM
15-01-2015 1:17 PM
15-01-2015 1:23 PM
Quote from: AndyH It could just be that your line was not stable enough after DLM increased your sync speed to 59996 and that the sync speed has adjusted on your next PPP drop, which happens to be when you disconnected following Matty updating your profile.
it dropped when MattyC changed the profile the graph shows the time of the sync drop which matches the time mattyC made the change that Is the point i'm making, everything was fine up until i made that request and the plusnet profile changed,
15-01-2015 1:27 PM
15-01-2015 1:32 PM
Quote the graph shows the time of the sync drop
Not quite, the graph shows PPP sessions to our RADIUS servers.
There is absolutely nothing showing wrong with your line or connection speeds. Yes they have dropped, but we've been over this in previous threads, this can happen as it's precisely how the DLM works.
15-01-2015 1:44 PM
there was Sync drop when my plusnet profile was changed so of course there wouldn't be anything wrong with my line or fault with it, the fault occurred at either the plusnet side of things, BTW or something in-between, something went wrong when the plusnet profile changed so why are you ignoring that fact. tell me why your so intent of not doing anything about this is the task to hard if so can you pass it to someone that would be willing and knowledgeable enough to do it
15-01-2015 1:49 PM
Quote I dont have a fault that needs to be reported you know that your just being funny and it's insulting
That really isn't my intention, apologies if it's coming across in that manner.
Quote something went wrong when the plusnet profile changed so why are you ignoring that fact.
I've not ignored that, AndyH has given a perfectly valid explanation of what could have happened. I'll reiterate, we cannot affect the sync directly from here.
Quote tell me why your so intent of not doing anything about this is the task to hard if so can you pass it to someone that would be willing and knowledgeable enough to do it
There is nothing we can do, we've explained how DLM works and that as there is no fault on the line, there is nothing we can do.
I'm now going to step away from this thread and leave my colleagues and other posters to respond.
