Incorrect profile setting
MARViN2003
Hello,
I think I may be on an incorrect profile, I have unlimited fibre extra, so I am expecting to be on an 80Mbps profile, but when I run the diagnostics check it shows as a 56Mbps profile.
 Download speedachieved during the test was - 54.5 Mbps
 For your connection, the acceptable range of speedsis 39.33 Mbps-56.19 Mbps .
 Additional Information:
 IP Profile for your line is - 56.19 Mbps
Upload speed achieved during the test was - 7.77Mbps
Thanks in advance
Fixes: 10
Re: Incorrect profile setting
The fact that the downstream is over 55 and the upstream is 20 confirms you are on the correct provision - 80/20. Factors such as the distance to the cabinet are limiting the sync speed. The downstream IP Profile is set just below the sync speed.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 184
Hi @MARViN2003 unfortunately it looks like this is simply down to the capability of the line, judging from the estimates:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 55 40 13.9 9 -- Available -- --
 Harry Beesley
Fixes: 10
Wow! Speed above the top estimate - your line is actually doing great!
Browni
Aspiring Hero
Fixes: 46
And the upload is lower than the bottom estimate...
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
MARViN2003
Thanks for the replies.  Glad it seems to be set right and it's just probably the distance to the cab.
It seems to have settled around that speed now, although I did do a speedtest last week and it was only downloadig at 5Mb/s.
