Incorrect Line Speed Showing in Member Centre
- Incorrect Line Speed Showing in Member Centre
25-03-2015 11:23 PM
I'm on FTTC, and have noticed that the line speed you have me set to, does not match the sync speed on my router.
Estimated line speed:
Current line speed:
20.7 Mb
But my Router shows:
Bearer: 0, Upstream rate = 4582 Kbps, Downstream rate = 25000 Kbps
As my sync did improve a few weeks back, I assume your system hasn't picked up this change? (Although surely it should refresh the info on a regular basis as the line speed is dynamic).
Current line speed:
20.7 Mb
Message 1 of 6
(1,119 Views)
5 REPLIES 5
Re: Incorrect Line Speed Showing in Member Centre
25-03-2015 11:42 PM
Plusnet rely on a 'delta report' from BT to tell them if your IP profile changes, sometimes this gets 'missed' for some reason (I don't think that happens too often nowadays), hopefully a staff member will pick this up and adjust it manually (probably in the morning now).
Call me 'w23'
Message 2 of 6
(767 Views)
26-03-2015 3:36 PM
It looks like the delta report mentioned by w23 kicked in and updated the profile last night. Are you able to confirm?
Matty
Matty
Message 3 of 6
(767 Views)
26-03-2015 3:50 PM
I still have
Phone exchange:
RUGBY
2.0Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-03-03 21:45:12
Current line speed:
64.8 Mb
My current line speed should be IRO 75 MB as am 300 ft from the cab
Phone exchange:
RUGBY
Current line speed:
64.8 Mb
Message 4 of 6
(767 Views)
26-03-2015 4:39 PM
Message 5 of 6
(767 Views)
27-03-2015 10:25 AM
Quote from: MattyC Hi there,
Matty
Thankyou - I'm now seeing the increased throughput.
Message 6 of 6
(767 Views)
