Improving connection in daughter's bedroom
- Improving connection in daughter's bedroom
06-12-2020 11:50 AM - edited 06-12-2020 12:05 PM
We live in an end terrace house. My daughter's bedroom is probably the farthest from the router. However we have a BT essentials WiFi extender 300 in her room but it changes from a green light (correct position) to an amber (too close to router) frequently. She has a desktop, internet connected light bulb and smart TV in her room. The internet connected light bulb and desktop only detect the extender connection. Her TV does detect the routers we have a Hub One connected into a Netgear Nighthawk XR500 but signal strength is very poor. We also have an open reach point in her bedroom but not sure if it is active. WiFi signal is intermittent. Any advice to improve signal greatly appreciated.
2 REPLIES 2
Re: Improving connection in daughter's bedroom
06-12-2020 12:46 PM
Although the Hub One light turned red I checked the open reach point and a dial tone can be heard when I plugged in a wired phone line.
06-12-2020 12:49 PM
These are your options, what's best for you is dependant on your house layout and budget. https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Distributing-Data-around-Larger-Proper...
