Impacted Line FTTC?
Benwilliams
Impacted Line FTTC?
Can You test my line please
Fixes: 190
Re: Impacted Line FTTC?
Our tests aren't showing any issues with your line and your speeds are where we'd expect them to be.
 Matthew Wheeler
Benwilliams
can i see the test please
Benwilliams
GEA line test
Fixes: 190
Here you go.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 27.6 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 1036.3
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off
Time Stamp 2017-03-17T15:15:00
 Matthew Wheeler
Benwilliams
ok can test my other account please [Removed] i just wanna check while im here thanks
Moderator's note by Mike (Mav): Personal information removed from a public forum to an area that staff can see.
Fixes: 190
Your other line test is below
Test Outcome Pass
Sync Status In Sync
Downstream Speed 64.6 Mbps
Upstream Speed 20.0 Mbps
Estimated Line Length In Metres 554.0
Downstream Rate Assessment Good
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-03-09T12:15:00
Parameters MIN
 Matthew Wheeler
Benwilliams
thanks for the help
