Image display issues
FIXEDTopic Options
- Re: Image display issues
23-11-2016 2:33 PM
Not sure if this is connected to my other issues but I can't seem to see any images on Wikipedia. I have disconnected and reconnected and rebooted the router
Cleared caches etc but nothing. Oddly if I switch to 4g it's all ok
Is this something that is connected to the packet loss issues or something concerned with my connection. Any help would be appreciated....
Fixed! Go to the fix.
Message 1 of 3
(614 Views)
2 REPLIES 2
23-11-2016 3:59 PM
Solved.... It appears plusnet safeguard causing the issues. Switched my tablet to static IP using google DNS and all OK! Switched off safeguard over 2hrs ago but still not taken effect and I've just done a disconnect and reconnect. Would plus net care to comment?
Message 2 of 3
(595 Views)
23-11-2016 4:19 PM
https://i.ytimg.com/vi/gT9xuXQjxMM/maxresdefault.jpg
