IPv6
Petevick
IPv6
I've just been connected to Plusnet fibre broadband, I'm using my own router which is a TP-Link TD-W8970. This has an option to enable IPv6, is there any benefit to enabling ?
Joshc
Re: IPv6
Hey,
Were are not currently using IPv6 at the moment, personally I do not think there would be any benefit enabling.However, other people may disagree.
Smiley
Petevick
Re: IPv6
Blimey, speedy reply !! Thanks for the information, I'll leave it disabled for now  Wink
Fixes: 10
Re: IPv6
There's a number of us on an IPv6 trial at the moment, but this has been going on for months. There are issues to be resolved before it could be rolled out (it doesn't work properly on all the newer Plusnet gateways) and there doesn't seem to be much progress.
You could try a 6in4 IPv6 Tunnel - see http://community.plus.net/forum/index.php/topic,106578.0.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Petevick
Re: IPv6
thanks for that jelv  Wink
