IPv6 disabled for this Internet service.
slavo71
As others internet went down at around 16.30, just came and tried again..still down. I rebooted modem and router and net is back up, speeds are OK but after I clicked the "Check connectivity to the Internet" the results show a big red X next to IPv6 with the message below: IPv6 disabled for this Internet service.
Can't remember seeing that before! Will it sort itself...is it something my side or Plusnets side causing it...or has it always been off???
Connection Information
Link Status:
IPv4 connected
IPv6 disconnected
5 REPLIES 5
Taaketa
Re: IPv6 disabled for this Internet service.
I don't think pnet is currently using IPV6 .
jelv
Fixes: 10
There are a very limited number of users who are trialling IPv6. One of the biggest issues at present is that it doesn't work properly on the new bng gateways.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
slavo71
OK guys thanks for the replies, just thought I'd ask as 1) not seen it before and 2) big drop out for all yesterday so thought I'd check Wink
Fixes: 156
Have you had a firmware upgrade?
IPv6 is supported in firmware 10.2.2.B
avatastic
Quote from: jelv
They also have trouble with IPv4 at times!  Grin
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
