IP profile suddenly halved
- Re: IP profile suddenly halved
11-10-2019 8:42 AM
My IP profile according to BT Wholesale test has suddenly dropped to 37.37Mbps. It used to be in the high 60's and I could get that that kind of download speed. I have escalated to Plusnet support, but they will not escalate to BT without Plusnet faults team checking it out which may take a week. Plusnet support claimed they can't see BT Wholesale test result anyway.
Is there any way this can be escalated? If the IP profile has suddenly halved, is this not by definition a line problem between the exchange and modem that BT Wholesale will have to deal with, and I'm not at risk of a £60 no fault found problem?
Question ID in my account is 194977168
11-10-2019 9:50 AM - edited 11-10-2019 9:51 AM
Have you done these basic fault finding tests to make sure that the problem is not on your premises?
1. Remove the front off the BT Master socket to expose the test socket.
2. Plug a wired telephone in here and do a quiet line test by dialling 17070 then option 2. If there's any background noise then report a phone fault.
3. Plug a filter in to the test socket and connect this to your router. With a computer connected to the router via an Ethernet cable complete the BT speed test. http://speedtest.btwholesale.com/ If this is showing your speed is low then go on and complete the further diagnostics to record the results then report a broadband fault.
Unless there has been a very recent unreported change then if you have completed the BT further diagnostics then Plusnet can see the results regardless of what you have been advised.
11-10-2019 10:05 AM
LIne is quiet. IP profile now showing a more respectable 65+Mbps, but download speed still bad. Not sure what's going on and why IP Profile is changing so rapidly. It was at 37 earlier today!
11-10-2019 2:10 PM
It is now worth trying a single router disconnect, leave it a minute then reconnect to see if that picks up a higher speed.
11-10-2019 2:13 PM - edited 11-10-2019 2:14 PM
Already done that. Router is separate from (external) modem anyway - my understanding is that router disconnect/reboots don't look like a line down to the exchange if the modems still connected, right? Modem was disconnected/reconnected once when I did the above test.
11-10-2019 5:32 PM
Hi @wibblyw,
I'm sorry to hear that you've experienced this issue with your connection. I've tested your line this afternoon and I can see that there's a potential fault, though we don't know the location. I can see this has been raised to our Faults Team to pick up, however we may be able to speed up the investigation process somewhat, though I would like to just double check that the internal checks have all been tried first. For example have you set your router up in the test socket and followed our troubleshooting guide? For reference, these can be found here and here.
11-10-2019 6:55 PM
11-10-2019 7:15 PM
A similar thing happened to my connection yesterday - I’ve started a thread too. When the staff suggested that there’s a line fault I wasn’t surprised as we’re a rural line which is poor quality. But it’s an odd coincidence?
12-10-2019 2:24 PM
