IP profile reset please
CrystalJayme
I just did a speed test with bt's speed test and I'm getting 18.9mbps downstream and 10.11mbps upstream on a 80/20 connection. Some reason my ip profile has gone from 76mbps to 73.9mbps. Could plusnet take a look at my connection stats from my router and also reset my ip profile. Thank you
12 REPLIES 12
adamwalker
Fixes: 221
Re: IP profile reset please
I've just looked into this and I can see the line profile has already updated automatically and is back to where it was before Monday.
 Adam Walker
CrystalJayme
Sorry but my ip profile has gone back to 73.9mbps. Could you reset my ip profile back so it goes to 77.35mbps Thank you
CrystalJayme
Added screenshot showing my router sync speed which is higher then BTW ip profile so I'm confused.
MatthewWheeler
Fixes: 479
I'm afraid that's not possible as we can't set profile higher than the sync rate
 Matthew Wheeler
CrystalJayme
My ip profile has always been 77.35mbps so what's happened?
Browni
Aspiring Hero
Fixes: 60
The IP profile is a percentage of the synch rate (usually 96.8%) so your synch rate must have changed.
Have a look here for a full explanation of IP profiles.
TheMightyAJ
Fixes: 126
Hi @CrystalJayme,
After testing your line today I can see that the Sync Rate has now increased to 76.3Mbps download speeds. In regards to the Sync Speeds these aren't always static and are subject to change due to various factors that may affect the line such as weather or other interference such as engineering work, however after reviewing it today I am happy to say that it seems like you're currently achieving the higher ends of your estimated speeds.
If this does seem to change, or you notice any other issues with the broadband connection in the future please let us know as soon as possible and we'll be more than happy to investigate further.
Moderator's note by Mike (Mav): Tag fixed.
 Alex H
CrystalJayme
Thanks TheMightyAJ for doing the test 🙂 x
CrystalJayme
Sorry to trouble you again but could you please upload the GEA Service Test so that I can see the screenshot. Thanks x
adamwalker
Fixes: 221
It's worth noting too that the test just flagged up an MSF (major service fault affecting your area, the estimated time for resolution is 15:49 today.
 Adam Walker
CrystalJayme
Thanks for the screenshot and letting me know about MSF which explains my fluctuating speeds today. I will keep an eye on it and if I see my speed go below 60mbps I'll let you know. X
adamwalker
Fixes: 221
No worries!
 Adam Walker
