IP profile lowered
- Re: IP profile lowered
IP profile lowered
05-05-2015 1:17 PM
Hi all,
I've been a fibre customer for almost 2 years, for all of that time i was enjoying speeds of 8.6MB/s (76 throughput i think) and a ping of 5
Recently, I began noticing download speeds maxing out at 7.2MB/s, I performed a speedtest and sure enough I'm now getting 65Mb. I went on the BT speed test and IP profile of 65 has been assigned. DLM has done nothing for a long time, after power cycling and the like.
I had explained this in the online chat with a plusnet rep and they told me to raise a fault, however I decided to check the forums and I'm seeing a lot of info about g.inp.
Would it be possible to check if my connection has had g.inp activated on it? If not, I would like to ask for an IP profile reset.
Thanks for any help
Thanks for any help
Message 1 of 2
(397 Views)
1 REPLY 1
05-05-2015 1:19 PM
Ok lets start this off in the right way
1) What modem/router are you using ? can you post an image ?
2) do you know what fibre cabinet you connect to ? can you post an image
3) Are you able to obtain any line stats from current equipment in use ?
4) Roughly when did you notice the speed drop occur ? had the line previously been stable to that for a long period of time ?
Message 2 of 2
(222 Views)
