IP profile downgraded?? After house electrical works. Can someone check please
- Re: IP profile downgraded?? After house electrical...
10-11-2015 4:43 PM
We've been having our home electrics supply upgraded & a load of rewiring done for an EV point. This has meant the modem & router have been off multiple times on multiple days.
Our download speed seems to have fallen as a result
Has the IP profile been downgraded?, if so can it be reset @ the start of next week when it has all been finished.
TIA
Mike
1. Best Effort Test: -provides background information.
Download Speed
13.77 Mbps
0 Mbps 14.52 Mbps
Max Achievable Speed
Download speedachieved during the test was - 13.77 Mbps
For your connection, the acceptable range of speedsis 11.61 Mbps-14.52 Mbps .
Additional Information:
IP Profile for your line is - 14.52 Mbps
Upload Speed
6.58 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 6.58Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
TIA
Mike
Download Speed
13.77 Mbps
0 Mbps 14.52 Mbps
Upload Speed
6.58 Mbps
0 Mbps 20 Mbps
Message 1 of 7
(891 Views)
6 REPLIES 6
Re: IP profile downgraded?? After house electrical works. Can someone check please
10-11-2015 4:53 PM
To add;
I keep trying to raise a support ticket through the web site but when I submit it I get 'An error occurred whilst processing your request'
Message 2 of 7
(547 Views)
12-11-2015 2:38 PM
So no reply to either a support ticket or here in over 24hrs.
Is PN CS going down hill or is it just me
Message 3 of 7
(547 Views)
12-11-2015 4:20 PM
If you are on fibre PN cannot reset the DLM. It's only possible if an engineer is sent out and isn't automatic even then. You'll just have to wait a few days after your electrics have been completed. Eventually the DLM will start to ease off and let the line speed increase.
Oh and the ticket system appears to be deprecated now. Use online chat or the telephone 😕
Message 4 of 7
(547 Views)
12-11-2015 4:24 PM
As Andure says, there isn't a tool to allow us to reset profiles on Fibre lines. If it doesn't improve ones the work is finished it'll need looking in to as a fault.
Message 5 of 7
(547 Views)
12-11-2015 7:19 PM
OK cheers for the replies chaps
I just couldn't find any info on the DLM & just assumed it 'was' possible to reset as per a new install
Message 6 of 7
(547 Views)
12-11-2015 7:59 PM
http://www.kitz.co.uk/adsl/DLM.htm
Quote from: BikerPa I just couldn't find any info on the DLM
Message 7 of 7
(547 Views)
