IP camera problems
- Re: IP camera problems
IP camera problems
07-02-2015 3:18 PM
Had my fibre for about a week now. Have had to reinstall my IP camera onto the network following my move from Sky. Now have it working on the network wirelessly and it is sending me emails when it is triggered but I still can't view it from my phone. I have used a No-IP ddns which seems fine but for some reason my phone (using IP cam viewer lite) cannot connect to the hostname or IP. It looks to me like it is being blocked but I can't figure out by what.
Colin
07-02-2015 3:47 PM
Mark
07-02-2015 3:48 PM
07-02-2015 5:31 PM
If using the TG582n, use game and application sharing to forward the necessary ports to the camera.
Also check plusnets firewall is disabled in your "members centre".
https://portal.plus.net/my.html?action=firewall
Need to renew the ppp session for the change to take affect.
07-02-2015 7:25 PM
07-02-2015 7:52 PM
Not the best explanation, but that is all I can give you without the router to help me.
Mark
07-02-2015 7:56 PM
That sounds like what I've done. Just found a walkthrough on the web and now it all works. All I'm bothered about now is whether I've left my router without a firewall.
07-02-2015 7:59 PM
Mark
08-02-2015 6:17 PM
08-02-2015 7:47 PM
I've had mine almost 2 years now, so there will be a better upgraded version I would think.
Mark
08-02-2015 7:55 PM
No need for any updating then as your IP address will never change!
I've had an IP camera for years. Its primary use is Security.
I can't help with the router as I use a TP-Link one. I found the supplied one had an awful & confusing interface!
York.
08-02-2015 8:08 PM
Mark
