IP address makes websites think I'm in the USA
- Re: IP address makes websites think I'm in the USA
21-07-2017 1:21 PM
The IP address I'm currently assigned by Plus.net makes it look to websites like I'm in the USA.
The address is in the range 146.198.110.X and is registered to "Info.net" with offices in El Segundo, USA.
This is stopping me from Banking online, using any geo services such as streaming video and imprtantly for me playing Poker on Pokerstars since online poker in the USA is illegal
This seems to be a recurrence of an issue from a few years ago judging by previous threads,
Any assistance on how to actually change my external IP address?
This is an extract from the "whois" of the IP address....
NetRange: 146.198.0.0 - 146.198.255.255
CIDR: 146.198.0.0/16
NetName: PLUSNET3
NetHandle: NET-146-198-0-0-1
Parent: NET146 (NET-146-0-0-0-0)
NetType: Direct Assignment
OriginAS: AS6871
Organization: INFONET Services Corporation (INFO)
RegDate: 1991-02-28
Updated: 2015-03-12
Ref: https://whois.arin.net/rest/net/NET-146-198-0-0-1
OrgName: INFONET Services Corporation
OrgId: INFO
Address: 2160 East Grand Avenue
City: El Segundo
StateProv: CA
PostalCode: 90245-1022
Country: US
RegDate:
Updated: 2017-01-28
Ref: https://whois.arin.net/rest/org/INFO
21-07-2017 1:29 PM
Getting a static IP address (one off £5 charge) appears the only way to avoid this.
21-07-2017 2:04 PM
I think PlusNet should waive a £5 charge given the circumstances. I assume it is only a quick config change on their system.
The problem is I think companies are more reliant on external IP's and assume what is and isn't UK based. It is not an exact science. I think BBC (iPlayer) and the National Lottery do this too. Worth checking them out, see if they work and raising it with support.
21-07-2017 2:27 PM
The details are correct, but whoever is providing the service must be using an out of date list, or using the wrong information for the blocking. Lots more detail on
We'll see if we can work out who needs contacting. Are you seeing any other problems with that IP address?
Ex-Broadband Service Manager
21-07-2017 2:52 PM
Kelly
For starters this has stopped my "Three in Touch" WiFi calling service since it only works in the UK. This means I've no mobile coverage at home.
Pokerstars have had me sign a disclaimer on line to assert I'm playing from the UK. I'd rather play without any shadows over my game.
Bizarrely my Facebook has become intermittent since this recent changeover to the new IP address. Not as important but annoying nevertheless
My Banking on an RBS subsiduary is now unreliable with random geo related security checks and queries on whether I am actually performing transactions or is it a hacking attempt.
Try that for starters if you can fix those then the rest will probably fall into place. I dont think its my place to tell Website service providers to update their IP records - wheres the credibility for me in that?
I've a JPG of a geo location whois service showing El Segundo as my location. Not sure if its safe to post the image here since it shows the full IP address.
21-07-2017 2:56 PM
Which WHOIS service are you using?
It's likely someone has updated a geolocation database incorrectly and that's been picked up by those services. We'll take a look.
21-07-2017 3:10 PM
Why not start the move to IPv6 @Kelly and remove the reliance on 2nd User IPv4 address ranges.
21-07-2017 3:15 PM
Agreed, even though it's not realy their fault it's others using out of date databases.
21-07-2017 4:06 PM
@MauriceC IPv6 will come after new billing system
21-07-2017 4:18 PM
@rongtw wrote:
.... IPv6 will come after new billing system
Now that is a meritorious piece of optimism.
21-07-2017 10:14 PM
Forget it.
I can;t carry on like this. This issue seems to have been kicking around since 2014 and is unlikely to be fixed satisfactorily.
Since I'm now out of contract I have instead placed an order to switch my broadband to an alternate provider.
If you want feedback,
It was two price rises during the contract period, this IP address issue and a meagre 2Mb/s upload speed that sealed the deal I'm afraid.
21-07-2017 11:23 PM
Can't say I blame you, with two out of those three reasons, good luck with your new provider.
22-07-2017 2:32 PM
Sorry to hear you're thinking of leaving us because of this issue
As an ISP, it's unfortunately out of our control that those geolocation databases are incorrect.
All the best with your new provider.
23-07-2017 12:27 AM
So RBS systems, Pokerstars and everyone else has a problem... But not plus net despite that IP address being on record as being at an address in el segundo in california?
How's about something that is in your control? Maybe you could have forced my IP address to renew to a less ambiguous one?
25-07-2017 12:46 PM
Hi @mikecro,
I've looked in to this and can confirm this has been flagged up with a few geolocation database providers/companies regarding the out of date data they have for some of our IP ranges. Hopefully we won't be waiting long for them to update their records.
