IP address advice please
winnipeg1823
Every couple of months my download speed drops by around 10 mbps. Then after a few weeks it reverts back to normal.
The upload speeds always remain unchanged
The speed drops, and increases always coincide with a change in the external IP address.
Is there anything that can be done to stop this happening.
6 REPLIES 6
Fixes: 419
Re: IP address advice please
@winnipeg1823
You could pay a fiver for a fixed IP address and hope that it’s a fast one. These come from a different range of addresses.
winnipeg1823
thanks for that.....do I get my money back if its a slow one 😂
pjmarsh
Fixes: 20
How are you measuring your speed?  ie.  is it the speed that your router is syncing at, or the speed seen on speedtests.  If it's your sync speed then that wouldn't be anything to do with your IP address.  If it's just on speedtests then maybe.
Your IP address may be a symptom of your issue, rather than the cause.  If your line is dropping enough, then this could cause DLM to reduce your sync speed.  A disconnect/reconnect may also cause your IP address to change, though you may also be given the same one sometimes.
Your assigned IP address doesn't affect your speed directly, though it could be some websites (including some speed test websites) are treating you differently based on the IP address.  For example some speed test sites will suggest which server you use for the test.  I've never paid too much attention to how they determine which server.  If it's done based on the "location" of your IP address, then that might suggest a server on the other side of the world, which may see reduced speeds.
winnipeg1823
The same speedtest site, roughly the same time daily, and it's clear over a year that the speeds alter at the same time the IP address changes. It doesn't really affect anything, but clearly something isn't quite right.
pjmarsh
Fixes: 20
Do you notice the slow down in speed, or just what the speedtest site gives you?  Is it the speedtest site that is giving you your IP address?  What speedtest site is it?  Do you see the same on other speedtest sites?
winnipeg1823
I don't notice the change much, I use two sites, each day, same time, both show the drop in speeds, and then the increase, and both show the same IP address
