IP Profile
- IP Profile
IP Profile
26-04-2015 6:55 PM
adie:red change all caps title as per link:rules]
Re: IP PROFILE
26-04-2015 7:30 PM
I'm not sure how much lower it should be but almost 2Mbps looks a bit excessive to me, I guess it's just slow to update.
For comparison this is my profile:
Quote Actual Sync speed: 24.79Mbps
BT Profile: 23.99 Mbps
PlusNet Profile: 22.8 Mbps
Actual Throughput: 21.93Mbps
Can someone at PN please give the profile script a good kick.
Re: IP PROFILE
27-04-2015 9:18 AM
I notice this morning my PN profile is now 23.8Mbps, the BT profile remaining the same as above.
Re: IP PROFILE
27-04-2015 4:29 PM
Re: IP PROFILE
27-04-2015 4:58 PM
Re: IP Profile
27-04-2015 6:14 PM
Re: IP Profile
27-04-2015 7:04 PM
You can find the BT profile by running the "BT Broadband performance test" then run the "further diagnostics"
http://speedtest.btwholesale.com/
You can find the PN profile ("Current line speed") in the member centre.
Re: IP Profile
27-04-2015 8:05 PM
thanks
Re: IP Profile
27-04-2015 8:25 PM
https://portal.plus.net/apps/kbdfaults/question
Re: IP Profile
27-04-2015 8:34 PM
Re: IP Profile
27-04-2015 8:46 PM
In my experience it can be annoyingly slow progress, a prod here can often help
Re: IP Profile
27-04-2015 9:18 PM
