IP Profile - where has the page to view this gone?
- IP Profile - where has the page to view this gone?
15-05-2019 12:16 AM
I think my IP profile at PN is stuck. My sync speed is 66Mbps, but I'm only seeing throughput around 52/54Mb.
Plusnet staff - please could you review and reset if appropriate?
Also, where has the page gone that allowed you to view the profile in your account? It used to be visible at https://portal.plus.net/my.html?action=stable_rate, but that link now takes me to the account homepage.
Re: IP Profile - where has the page to view this gone?
15-05-2019 12:31 AM - edited 15-05-2019 12:40 AM
Plusnet have removed it
The following statement was made on 04/03/19
I looked into this earlier, it appears that we've retired this page in advance of a new page being added in an upcoming release. Sorry for the inconvenience.
(the main topic (one of a few) is here)
We've heard nothing to date regarding it's replacement...
edit. I should have added that we can see the profile by carrying out the full test on the BTw speedtester site
( if you need it - http://speedtest.btwholesale.com/ )
15-05-2019 7:58 AM
Thanks for the tip about the BT Tester; I'll give that a try.
15-05-2019 8:19 AM
I've tried using the BT tester, and it does show me a line profile, but isn't this the profile set at the exchange, rather than the rate limit that Plusnet imposes through it's profile?
The page I linked to used to show the profile for your line at Plusnet. This often gets out of sync with the 'exchange' profile. In my case right now, for example, the exchange profile is ~65Mb, but throughput is only about 54Mb. I think that's because Plusnet's profile for my line is lower than 65Mb. Historically, I'd have checked this on the Plusnet website and then raised a ticket for manual intervention at Plusnet to reset the profile. Without the webpage that shows my profile, I can't do that.
15-05-2019 9:46 AM
There was a bit of a 'debate' when we discovered it was being taken down....
What @MisterW wrote here should answer most of the rest for you.
Plusnet should be able to give you some idea of your profile.
In the last several months there's been a few others whom have noticed a reduction, but why that is is something I can't answer.
15-05-2019 9:58 AM
Thanks @DS.
MisterW's experience in the post you linked to does not reflect my own. Several times in the past, when my line sync speed has increased, I've observed that my actual throughput is lower than it should be. On every occasion, this has been because Plusnet's profile for my line is lower than BT's, and I was able to determine that by looking in my account on the Plusnet portal, and then contacting support to have it corrected.
Fingers crossed the Plusnet staff will see this post, update my profile, and also feed back internally that we need the profile to be visible to end users in the portal again. This level of detail and recognition that not all end users want to simply plug and play that set Plusnet apart. I really hope this isn't a sign of its strategy moving away from that approach.
15-05-2019 10:02 AM
Looking back at previous posts about this, it seems that the Plusnet profile does affect my throughput speed, because I have a static IP address: https://community.plus.net/t5/Fibre-Broadband/IP-Profile-stuck/m-p/1598789#M87129
15-05-2019 10:10 AM - edited 15-05-2019 10:10 AM
Hi @garywood84
I've increased the profile to 66000kbps to match the sync rate you've posted last night, if you do a single disconnect and reconnect of the PPP session you should see an increase in your throughput.
For the vast majority of customers this profile doesn't have any impact, however there are a few it does affect generally they have a static IP and the profile can be occasionally a bit slow to update automatically.
This has been discussed at length Here (the same link that DS has posted) and I'm afraid I'm not confident I could provide any more information than what we've already said there.
15-05-2019 10:17 AM - edited 15-05-2019 10:24 AM
No problem
Your first paragraph is exactly how it's reported by others. One might assume it was deliberate and they are struggling to cope and thus they apply the brakes a little and it is only those whom spot it and then they release the brakes. A little like how VM do things.
The 'normal' reply from Plusnet is it's the automated systems, but why can a human (staff) manually nudge some of these connections and boom they're back to where they used to be...?
But others may just think it's how the systems operate
I really can't see Plusnet back pedaling on this. My gut feeling is the replacement will be similar to the one on offer from BT - where you go to a website and it shows the speed from the device to the router and from the router to the internet. (whereas on the old method there wasn't all the bells and whistles).
edit. Ah, due to personal reasons it's taking me a while to compose a reply, thus both of those above were not there when I started.
15-05-2019 9:20 PM
15-05-2019 11:24 PM
All I can suggest is to give it 2-3 days now you've rebooted the router. Hopefully it'll sort itself out by then....?
16-05-2019 10:24 AM
Hi @garywood84
@DS is right in that sync speed can take a little while to increase after a profile reset.
If the upload speed doesn't improve within a couple of days, we'd potentially need to raise this to our suppliers, however, there's no guarantee that an engineer visit would be able to identify a fault and/or improve your upload speed - we're happy to try though, just let us know.
Best wishes
Dave
