IP Profile reset request
- IP Profile reset request
06-11-2021 1:18 PM - edited 06-11-2021 1:23 PM
Requesting an IP profile reset
For the past 6+months th eline has been very unstable. Intially i was seeing speeds fo 65mb down and 18-19mb down It then dropped to 45mb down. now it keeps creeping down to 30mb then 8mb and was 5mb before i restarted the router whioch brought it back up to 8mb.
The line flucuates alot now mostlty at the speeds of 8/15/30mb. as you can can also see in the screenshot the upload speed which normally is uneffected has over halved in speed to 9mb.
Ping is very high at 30-47 too.
Was previosuly with BT on a stable 67mb down and 19 up. with a stable ping of around 8-15ms around the clock.
Another issue is if i were at full speed, and to download something over 9mb/s it would knock out my connection to the router for a few mins without fail every time
Re: IP Profile reset request
06-11-2021 1:28 PM
After a second router reset and 30mins later after the Previous screenshot of the speed test
20mb down - 12mb up - 20ms ping
06-11-2021 1:30 PM
@BlackEagle That doesn't quite look to me to be a 'profile' problem - more like a network one to be honest. I suggest you follow my 'check' guide as below, excluding the BTW test which you have already completed.
For Community members to be able to help, information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
06-11-2021 1:50 PM - edited 06-11-2021 1:52 PM
I do not hear any noise from the Quiet Line Test.
BTW performance tester in the screeenshot.
06-11-2021 1:58 PM
Thanks for that. No noise from the QLT is good.
Can you post your Help Desk from the router, please, and the WAN tab from the Event log? Picture below to help.
06-11-2021 2:32 PM
Help Desk -> See Screenshot
WAN Log -> See below
Recorded events
Time and date | Message |
13:01:54, 06 Nov. | ( 136.800000) WAN operating mode is VDSL |
13:01:54, 06 Nov. | ( 136.800000) Last WAN operating mode was VDSL |
13:01:53, 06 Nov. | ( 135.350000) PPP IPCP Receive Configuration ACK |
13:01:53, 06 Nov. | ( 135.350000) PPP IPCP Send Configuration Request |
13:01:53, 06 Nov. | ( 135.340000) PPP IPCP Receive Configuration NAK |
13:01:53, 06 Nov. | ( 135.340000) PPP IPCP Send Configuration ACK |
13:01:53, 06 Nov. | ( 135.330000) PPP IPCP Receive Configuration Request |
13:01:53, 06 Nov. | ( 135.320000) PPP IPCP Send Configuration Request |
13:01:51, 06 Nov. | ( 134.050000) PPPoE is up - Down Rate=72928Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB |
13:01:51, 06 Nov. | ( 134.040000) CHAP authentication successful |
13:01:51, 06 Nov. | ( 134.000000) CHAP Receive Challenge |
13:01:51, 06 Nov. | ( 134.000000) Starting CHAP authentication with peer |
13:01:51, 06 Nov. | ( 133.990000) PPP LCP Receive Configuration ACK |
13:01:51, 06 Nov. | ( 133.990000) PPP LCP Send Configuration Request |
13:01:51, 06 Nov. | ( 133.980000) PPP LCP Receive Configuration Reject |
13:01:51, 06 Nov. | ( 133.980000) PPP LCP Send Configuration ACK |
13:01:51, 06 Nov. | ( 133.980000) PPP LCP Receive Configuration Request |
13:01:51, 06 Nov. | ( 133.980000) PPP LCP Send Configuration Request |
13:01:01, 06 Nov. | ( 83.880000) PTM over DSL is up |
13:00:13, 06 Nov. | ( 35.370000) WAN Auto-sensing running. |
12:12:06, 06 Nov. | ( 136.030000) WAN operating mode is VDSL |
12:12:06, 06 Nov. | ( 136.030000) Last WAN operating mode was VDSL |
12:12:05, 06 Nov. | ( 134.670000) PPP IPCP Receive Configuration ACK |
12:12:05, 06 Nov. | ( 134.660000) PPP IPCP Send Configuration Request |
12:12:05, 06 Nov. | ( 134.650000) PPP IPCP Receive Configuration NAK |
12:12:05, 06 Nov. | ( 134.650000) PPP IPCP Send Configuration ACK |
12:12:05, 06 Nov. | ( 134.650000) PPP IPCP Receive Configuration Request |
12:12:05, 06 Nov. | ( 134.630000) PPP IPCP Send Configuration Request |
12:12:04, 06 Nov. | ( 133.440000) PPPoE is up - Down Rate=73354Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB |
12:12:04, 06 Nov. | ( 133.420000) CHAP authentication successful |
12:12:04, 06 Nov. | ( 133.360000) CHAP Receive Challenge |
12:12:04, 06 Nov. | ( 133.360000) Starting CHAP authentication with peer |
12:12:04, 06 Nov. | ( 133.360000) PPP LCP Receive Configuration ACK |
12:12:04, 06 Nov. | ( 133.360000) PPP LCP Send Configuration Request |
12:12:04, 06 Nov. | ( 133.350000) PPP LCP Receive Configuration Reject |
12:12:04, 06 Nov. | ( 133.350000) PPP LCP Send Configuration ACK |
12:12:04, 06 Nov. | ( 133.350000) PPP LCP Receive Configuration Request |
12:12:04, 06 Nov. | ( 133.350000) PPP LCP Send Configuration Request |
12:11:14, 06 Nov. | ( 83.490000) PTM over DSL is up |
12:10:25, 06 Nov. | ( 34.910000) WAN Auto-sensing running. |
15:20:59, 21 Oct. | ( 134.140000) WAN operating mode is VDSL |
15:20:59, 21 Oct. | ( 134.140000) Last WAN operating mode was VDSL |
15:20:58, 21 Oct. | ( 132.840000) PPP IPCP Receive Configuration ACK |
15:20:58, 21 Oct. | ( 132.830000) PPP IPCP Send Configuration Request |
15:20:58, 21 Oct. | ( 132.820000) PPP IPCP Receive Configuration NAK |
15:20:58, 21 Oct. | ( 132.820000) PPP IPCP Send Configuration ACK |
15:20:58, 21 Oct. | ( 132.810000) PPP IPCP Receive Configuration Request |
15:20:58, 21 Oct. | ( 132.800000) PPP IPCP Send Configuration Request |
15:20:57, 21 Oct. | ( 131.700000) PPPoE is up - Down Rate=73311Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.0dB |
15:20:57, 21 Oct. | ( 131.680000) CHAP authentication successful |
15:20:57, 21 Oct. | ( 131.640000) CHAP Receive Challenge |
15:20:57, 21 Oct. | ( 131.640000) Starting CHAP authentication with peer |
15:20:57, 21 Oct. | ( 131.640000) PPP LCP Receive Configuration ACK |
15:20:57, 21 Oct. | ( 131.630000) PPP LCP Send Configuration Request |
15:20:57, 21 Oct. | ( 131.630000) PPP LCP Receive Configuration Reject |
15:20:57, 21 Oct. | ( 131.630000) PPP LCP Send Configuration ACK |
15:20:57, 21 Oct. | ( 131.620000) PPP LCP Receive Configuration Request |
15:20:57, 21 Oct. | ( 131.620000) PPP LCP Send Configuration Request |
15:20:07, 21 Oct. | ( 81.560000) PTM over DSL is up |
15:19:20, 21 Oct. | ( 35.310000) WAN Auto-sensing running. |
23:35:03, 27 Sep. | (2008191.130000) WAN operating mode is VDSL |
23:35:03, 27 Sep. | (2008191.130000) Last WAN operating mode was VDSL |
23:35:01, 27 Sep. | (2008189.200000) PPP IPCP Receive Configuration ACK |
23:35:01, 27 Sep. | (2008189.190000) PPP IPCP Send Configuration Request |
23:35:01, 27 Sep. | (2008189.180000) PPP IPCP Receive Configuration NAK |
23:35:01, 27 Sep. | (2008189.180000) PPP IPCP Send Configuration ACK |
23:35:01, 27 Sep. | (2008189.170000) PPP IPCP Receive Configuration Request |
23:35:01, 27 Sep. | (2008189.090000) PPP IPCP Send Configuration Request |
23:35:00, 27 Sep. | (2008187.300000) PPPoE is up - Down Rate=73526Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB |
23:34:59, 27 Sep. | (2008187.290000) CHAP authentication successful |
23:34:59, 27 Sep. | (2008187.230000) CHAP Receive Challenge |
23:34:59, 27 Sep. | (2008187.230000) Starting CHAP authentication with peer |
23:34:59, 27 Sep. | (2008187.230000) PPP LCP Receive Configuration ACK |
23:34:59, 27 Sep. | (2008187.230000) PPP LCP Send Configuration Request |
23:34:59, 27 Sep. | (2008187.220000) PPP LCP Receive Configuration Reject |
23:34:59, 27 Sep. | (2008187.220000) PPP LCP Send Configuration ACK |
23:34:59, 27 Sep. | (2008187.220000) PPP LCP Receive Configuration Request |
23:34:59, 27 Sep. | (2008187.220000) PPP LCP Send Configuration Request |
23:34:08, 27 Sep. | (2008135.760000) PTM over DSL is up |
23:33:31, 27 Sep. | (2008099.240000) PTM over DSL is down after 20115 minutes uptime |
23:33:31, 27 Sep. | (2008099.240000) PPPoE is down after 20114 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
23:33:28, 27 Sep. | (2008095.520000) PPP LCP Send Termination Request [User request] |
00:19:06, 14 Sep. | (801241.100000) WAN operating mode is VDSL |
00:19:06, 14 Sep. | (801241.100000) Last WAN operating mode was VDSL |
00:19:04, 14 Sep. | (801239.840000) PPP IPCP Receive Configuration ACK |
00:19:04, 14 Sep. | (801239.840000) PPP IPCP Send Configuration Request |
00:19:04, 14 Sep. | (801239.820000) PPP IPCP Receive Configuration NAK |
00:19:04, 14 Sep. | (801239.820000) PPP IPCP Send Configuration ACK |
00:19:04, 14 Sep. | (801239.820000) PPP IPCP Receive Configuration Request |
00:19:04, 14 Sep. | (801239.810000) PPP IPCP Send Configuration Request |
00:19:03, 14 Sep. | (801238.730000) PPPoE is up - Down Rate=70483Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB |
00:19:03, 14 Sep. | (801238.710000) CHAP authentication successful |
00:19:03, 14 Sep. | (801238.680000) CHAP Receive Challenge |
00:19:03, 14 Sep. | (801238.670000) Starting CHAP authentication with peer |
00:19:03, 14 Sep. | (801238.670000) PPP LCP Receive Configuration ACK |
00:19:03, 14 Sep. | (801238.670000) PPP LCP Send Configuration Request |
00:19:03, 14 Sep. | (801238.660000) PPP LCP Receive Configuration Reject |
00:19:03, 14 Sep. | (801238.660000) PPP LCP Send Configuration ACK |
00:19:03, 14 Sep. | (801238.660000) PPP LCP Receive Configuration Request |
00:19:03, 14 Sep. | (801238.660000) PPP LCP Send Configuration Request |
06-11-2021 2:36 PM
Your WAN log is showing a number of disconnections from the network - which isn't a good sign. Can't see the Help Desk screenshot.
06-11-2021 2:40 PM
Correct, i have to frequently restart the router in an attempt to sometimes "fix" the slow connection
My appologies i didnt upload it
06-11-2021 2:50 PM
Thanks for that. From the Help Desk picture, the only thing that stands out is the 3dB U/S noise margin, although that could be a red-herring, given your line and signal attenuation figures - you must be sat almost on top of your local cab.
To be honest, I can't see anything in the detail you have provided to give rise to your connection problems, but a profile problem it certainly isn't.
Hopefully, one of the Help Team will pick this up and carry out tests which may give us a better clue as to the problem, but please be aware it is the weekend and they are a little thin on the ground.
I would avoid rebooting the hub too often - eventually DLM will assume you have a problem and intervene.
06-11-2021 2:55 PM
Sorry to but in but I can only see one disconnection, this was after being up for 14 days, the rest are CHAP requests.
The line connection is good.
I suspect that this is a wireless issue.
@BlackEagle are you testing over a wireless link? If so see what it's doing over an Ethernet connection.
06-11-2021 2:59 PM
No problem, @Baldrick1 - I admit to misreading that log. I also suspect a wireless issue, having been thinking about it.
06-11-2021 3:01 PM - edited 06-11-2021 3:03 PM
This is over Wireless, Ethernet is not currently possible unless i were to get 40m ethernet cable. Like i say before i used to sit at 60mb up and 18 down over wireless (using Asus pc-88 wireless card + external antena's). recently its been capping out at 40-45mb and often sitting at 30/15/8mb til a restart the router with 50/50 success chance of it going back up to 45mb.
EDIT: I also own a cheap £5 2.4ghz wireless usb and it is also giving the same results.
06-11-2021 3:05 PM - edited 06-11-2021 3:05 PM
It is possible in that case it could be the hub - did you use another one when getting the higher speeds?
06-11-2021 3:10 PM
Nothing has changed in the past two years. locations, hub, pc/wireless adapter.
06-11-2021 3:11 PM
It’s not expensive if you are desperate https://www.amazon.co.uk/World-Data-BLACK-Premium-Network/dp/B00O91S44K/ref=sr_1_5?adgrpid=568172035...
If you log in to the hub you can see the firmware version. If it ends 263 or earlier then there’s a firmware update that might help, add a message to this thread. https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510
