IP Profile Slowly Dropping
JIMMYDSHAW
Is there any chance of getting my ip profile raised? When I first got fibre it was running at over 30mbps but over the past months it's dropped to 25mbps even though it should be running at between 31 and 41mbps.
Fixes: 58
Re: IP Profile Slowly Dropping
Very little chance if the speeds are within the impacted range as given here http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput as you are probably suffering from cross talk
If it is lower then raising a fault at https://faults.plus.net is the way to go
JIMMYDSHAW
Thanks for your help.
