IP Profile Reset
FIXED- Subscribe to RSS Feed
- IP Profile Reset
- « Previous
- 1
- 2
- Next »
Re: IP Profile Reset
02-06-2021 1:12 PM
As I suspected it was on the wrong product, I thought it unlikely that DLM would apply banding on both upstream and downstream at exactly the same speeds as unlimited fibre.
02-06-2021 1:25 PM - edited 02-06-2021 1:26 PM
Yes, thanks Townman and RealAleMadrid marked as answer accepted. I'll keep checking but presume all will be sorted.
Thanks again!
04-06-2021 8:48 AM
Hi Gandalf,
Thanks for the help. Now getting 80/20 on the DSL Status as below on my DrayTek 2860n:
https://snipboard.io/l8hkgv.jpg
Also run a speed test:
BT Wholesale Speed Test: https://snipboard.io/svSDB8.jpg
Seems the download is still ranging from 20/30 Mbps only. I have run multiple times. Upload speed is spot on.
Any ideas?
04-06-2021 8:52 AM
04-06-2021 8:56 AM
Is this user on a fixed IP?
This reads like the old stuck IP profile issue but I thought that was long history with the “new” network?
04-06-2021 8:58 AM
04-06-2021 9:10 AM
Perfect spot on thanks speeds are correct now.
Again, many thanks all for you help, greatly appreciated.
All sorted now. Take care.
04-06-2021 9:14 AM
Awesome! No problem at all @blandyuk
Let us know if there's anything else you'd need help with
- « Previous
- 1
- 2
- Next »
