IP Profile Reset
FIXED- Subscribe to RSS Feed
- IP Profile Reset
29-05-2021 8:49 AM
Hi all,
Just moved to a new house and initial broadband attainable speeds were not good mainly due to awful wiring in the house. Around 4 sockets, some with 3 wires croned in! Attainable speed was ~22399 Kbps so bad.
Anyway, disconnected them all from the main wire and installed a new master socket so nothing else now, nice and clean.
My DrayTek says my attainable speed is now down ~95174 Kbps with up to 30026 Kbps.
Seems my IP Profile is stuck unless I need to wait a few days? Any help would be great.
Thanks!
Fixed! Go to the fix.
Re: IP Profile Reset
29-05-2021 9:49 AM
What are the current connection speeds, attenuation and noise margins?
Attainable speeds are only estimates.
What does https://www.broadbandchecker.btwholesale.com/#/ADSL report for the expected line speeds?
Regards
Richard
29-05-2021 9:52 AM
Hi, just spoken with Plusnet and it should sort itself out in the next few days. The logs their end could see errors but since yesterday, its been fine so seems to be sorted so hopefully the line will re-profile over next few days.
I'll see what happens.
29-05-2021 9:55 AM - edited 29-05-2021 9:57 AM
@blandyuk
If it doesn’t improve then ask for the results of a GEA test. That will tell you/us (if you copy it here) whether the line is banded. If it is then Plusnet can ask for a reset. This can get missed by some less experienced Plusnet agents.
29-05-2021 10:20 AM - edited 29-05-2021 10:22 AM
Post Deleted by @RealAleMadrid
02-06-2021 9:40 AM
OK, thanks for the replies. It has increased, so hopefully it will sort itself in a few more days. Here are some screenshots:
DrayTek DSL Status: https://snipboard.io/uVvKbF.jpg
https://snipboard.io/uVvKbF.jpghttps://snipboard.io/uVvKbF.jpghttps://snipboard.io/uVvKbF.jpghttps://snipboard.io/uVvKbF.jpghttps://snipboard.io/uVvKbF.jpgBT Wholesale Check: https://snipboard.io/1Gg0RU.jpg
02-06-2021 10:41 AM
Those stats indicate that the line is banded - you will need Plusnet to rectify this.
If this post helped, please click the Thumbs Up and if it fixed your issue, please click This fixed my problem
02-06-2021 10:53 AM
@blandyuk What Plusnet fibre product have you got? Your modem/router stats suggest you are on the Unlimited fibre i.e 40Mbps down /10 Mbps up is this what you expect, your line will obviously support the Fibre Extra service 80/20 Mbps.
@Townman Don't think it banded apart from being capped at 40/10 by the product. The odd thing is that the observed speed on the checker is 76.21 Mbps down which is not possible with the supplied stats, I have seen a few examples of the checker observed speed being somewhat suspicious.🙄
02-06-2021 10:56 AM
Doh!! I had not considered the possibility of being on basic fibre! 🙃
02-06-2021 11:02 AM
My theory is that it is not actually the maximum observed speed, rather it is the 'Observed Maximum speed' i.e it is the calculated maximum speed from the observed line stats.
02-06-2021 11:15 AM
I'm on Unlimited Fibre Extra 80/20.
Estimated peak time speeds: |
Download: 67 - 72Mb |
These are the speeds your line is capable of at peak times. |
Current line speed: 38.4Mb |
This is a measure of the actual line speed you are now receiving based on the product you have taken. |
Minimum Guaranteed Speed: 62Mb |
This is the minimum speed you should expect to achieve on your line. |
02-06-2021 11:22 AM
In which case my comment above stands. Either...
- You have been provisioned on the wrong product (40/10) instead of Extra
- Your line has been banded
No amount of waiting will fix either of these scenarios.
02-06-2021 11:51 AM
OK, thanks. Called Plusnet, and they confirmed I was banded, so they have removed the restriction so will give a couple of days and will see.
Thanks for the help so far all
02-06-2021 1:08 PM
Thanks for your post @blandyuk and welcome to our community forums.
Looking into this, your fibre isn't actually banded. We've provisioned you on 40/10 in error and the adviser you've spoken to has raised a request for our automated system to place a modify order to change the provisioned speed to 80/20.
This should go through tomorrow, normally in the early hours. Let us know how you get on
02-06-2021 1:12 PM
OK ... so the other option was applicable ... good that the questioning has non-the-less delivered a good resolution! 😉
