IP Profile Check Please
- Re: IP Profile Check Please
18-05-2015 4:53 PM
18-05-2015 4:58 PM
Downstream Speed 57.4 Mbps
Upstream Speed 20.0 Mbps
Profile Name 0.128M-60M Downstream, Retransmission High - 0.128M-20M Upstream, Retransmission Low
18-05-2015 5:21 PM
I was using an ECI modem and on a faster profile not too long ago but it seemed to go downhill around the time g-inp was switched on.
I have now changed over to a Huawei hoping that would have helped but it is still the same apart from a much lower latency.
Below is the stats from the modem if you can see anything out of the ordinary.
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 24482 Kbps, Downstream rate = 69068 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 60000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 8.3 8.5
Attn(dB): 17.9 0.0
Pwr(dBm): 12.5 7.4
Thanks.
James.
18-05-2015 9:22 PM
19-05-2015 12:42 AM
19-05-2015 7:02 AM
19-05-2015 10:05 AM
19-05-2015 9:02 PM
Shouldn't I potentially be able to get close to the max speed listed in the modem stats?
19-05-2015 9:35 PM
Thanks.
I don't suppose PN could push Openreach into enabling G.INP on my line?
Its annoying not knowing whether the feature is supported or not on the DSLAM, or if there is some kind of profile issue.
19-05-2015 9:49 PM
you can get the firmware here on the Kitz forum if you need it http://forum.kitz.co.uk/index.php/topic,14262.0.html
other than that i have no other clue why speeds haven't increased.
19-05-2015 10:42 PM
21-05-2015 8:09 AM
Quote from: elfish Please could you post my profile info?
Thanks.
Please?
