IP Geolocation Question
- Re: IP Geolocation Question
04-01-2016 8:30 PM
So I require an IP address which is geographically specific to N. Ireland.
Does anyone know if Plusnet can provide this ?
04-01-2016 8:32 PM
edit: corrected my mistake.
04-01-2016 8:41 PM
I may consider the vpn route but I just wanted to check that there was no free way of doing this. I believe that some other ISPs maintain a pool of IPs specifically for NI.
04-01-2016 8:52 PM
04-01-2016 9:15 PM
How much does a static IP cost ?
04-01-2016 9:20 PM
04-01-2016 9:27 PM
What do I do next to change to NI location ?
04-01-2016 9:36 PM
04-01-2016 9:41 PM
05-01-2016 8:09 AM
06-01-2016 5:59 PM
It may take RTE a little longer to adopt the changes.
