I need PN to look into this
jockwav
I have done a few things to test the water with another isp,what i have been told is that PN have not updated their records to show that i even have a phoneline & broadband,can someone look at this for me.Huh
https://www.flickr.com/photos/james_bingham/
9 REPLIES 9
Darkfire
Fixes: 30
Re: I need PN to look into this
Hi Smiley
I've just taken a look and the address your line is registered under with Openreach matches the one we have on your account, this line is showing an active FTTC connection under the same address.
I've sent you an email from your account with the full address we have for you which is the same as what Openreach hold Smiley
jockwav
Thanks for that,can i send you a message about the update on this postcode.
Darkfire
Fixes: 30
Sure thing, if you need it updating let me know and we'll get it sorted Smiley
jockwav
how do i message you
Oldjim
Resting Legend
Fixes: 63
click on his user name
jockwav
Thanks oldjim sortedSmiley
jockwav
Thank you Darkfire for phoning me.Smiley
Darkfire
Fixes: 30
No problem, much easier with address issues to actually talk about the problem, simple fix though Smiley
jockwav
I have just found out for anyone looking into this,BT Openreach Database is updated by them on the 24th of every month.Smiley
