I have fixed wiring issue in my house is it possible to get a DLM request without an engineer visit
FIXED- Subscribe to RSS Feed
- I have fixed wiring issue in my house is it possib...
- « Previous
- 1
- 2
- Next »
Re: I have fixed wiring issue in my house is it possible to get a DLM request without an engineer...
16-06-2021 10:19 AM
Thanks for the update @bert1e
How long's the cable? Is it an extension cable or of an ordinary length?
16-06-2021 10:24 AM
Its 10m long with rj11 connectors (male) on either end. On the phone socket end I have it going into a filter and then into the test socket. At the other end I have a brand new RJ11 female to female connector and the lead from my router is plugged into that
16-06-2021 10:27 AM
Thanks for getting back to me @bert1e
If possible do you have a shorter cable of a standard length?
Long cables between the router and the telephone socket are common for causing issues especially on fibre.
16-06-2021 10:58 AM
@Gandalf I am afraid I dont have a shorter length cable the only way I could do it is trailing cables all over the floor and its not practical. Mains is not near the phone socket. That cable length (10m) is relatively short compared to the BT wiring. The BT wiring comes into the house at the front door into a BT52A junction box then over the top of a door frame back into another BT52A junction box and then back outside, goes round to the back of the house, back into the house and into the master socket.
16-06-2021 11:22 AM
I think for the purpose of a test before we potentially book an engineer, it's worth getting your hands on a shorter cable to use. I appreciate the BT wiring is longer, and that's likely fine, but the long extension cable would be adding to the loop loss.
Is it possible to use a shorter DSL cable and a power extension cord? Just for testing purposes as it'll narrow things down where the problem may lie. Wanting to avoid an engineer call out charge should the issue be the long cable.
16-06-2021 11:52 AM
I will do a one off test this evening moving the router to the master socket and see if the Attainable throughput number increases. That way we can work out what impact my own internal cables are having.
I will need to put the router back after the test as I cant move NAS, DECT phones and VM host which I will need for work tomorrow.
16-06-2021 11:57 AM
No problem @bert1e
Let us know how it goes
16-06-2021 4:19 PM
@Gandalf So I have done the test and have attached the results. It looks like I get 10Mbps more download speed using the short cable (as in the router plugged into the socket). So Short cable=48Mbps down while long cable round the room = 38Mbps.
So I dont think there is any point in arranging an engineer visit I will live with 38Mps for now until I can work out how to re-arrange the room to get the router closer to the socket.
Thank you for all the support and help you have given me. I have still ended up with a massive speed improvement (27 to 38) over what I had before.
cheers
16-06-2021 4:28 PM
Ah nice, I'm glad to see that's increased your speed although you've now likely got a bit of faff to rewire things.
No problem at all for the support, let me know if there are further issues or anything else you'd need help with.
Cheers
- « Previous
- 1
- 2
- Next »
