I can only assume we are being throttled?
- I can only assume we are being throttled?
31-10-2020 4:37 PM
Third time out for Openreach.
Engineer is getting 60MB download, however when I log on Via Plusnet hub OR Draytek 3762, am getting a max of 25MB and often the upload is faster than the download.
Worst speed is 5MB upload best 3 weeks ago was 50... Have had the cable from the post replaced..
Thought BT/Plusnet didn't throttle?
Re: I can only assume we are being throttled?
31-10-2020 4:41 PM - edited 31-10-2020 4:41 PM
@labuckland Welcome to the forums
PlusNet do not throttle, but you might have a stuck profile.
The other possibility is an internal wiring issue.
Are these speeds you are getting via a wired connection or Wi-Fi ? If Wi-Fi you need to test via a wired connection, as Wi-Fi can be subject to local interference.
31-10-2020 4:44 PM - edited 31-10-2020 4:56 PM
@wakeman ,
Thank for the reply..
It's a wired connection, no wifi enabled, new cable between socket & router, new socket plate, only connection to the router is from my desktop (or via a laptop to check it wasn't the desktop - same results)..
Are you able to tell me how I get the profile reset?
TIA
Adam.
31-10-2020 6:17 PM
01-11-2020 6:20 AM
Wouldn't that also affect the Engineers readings?
01-11-2020 8:14 AM
